Cayman 718 GPF Failure
Thanks Guys
Hopefully they will contact us, this is their reply.
Hi Guys & Girls
Following on from our last post, regarding the ash load % adaptation possibility, here's a quick update on what we have been doing so far.
We have managed to carry out an adaptation on three vehicles, and change the ash load % to zero, without having to do a static regeneration.
When we carried out these adaptations, the soot warning light came on with DTC P2463 (Particulate filter soot load to high) showing very high values in both the measured and calculated values.
Remember we never see soot warning messages displayed on the dashboards on these cars, even when the filter is supposedly blocked with Ash.
So these cars came in with the ash load % light on, with the DTC code P242F present and showing a 100% ash load value. And has usual, the measured and calculated soot values showing 0.00%, (no soot present).
And also the differential pressure sensor readings were showing no pressure at all which is always the case.
So when the ash% value was changed to 0.00% the soot values appeared, which is crazy when they weren't there before, how can soot just come from nowhere ?.
So on the first 2 cars a static soot regeneration was carried out, the soot values dropped the light went out, and the cars were given back to their owners for us to monitor the ash % going forward.
Regarding our 3rd car, we are going to carry out road testing to see if passive soot regeneration will lower the soot values which should put out the warning light.
Will keep you informed of its progress.
The reason we are posting this information early is, we don't want owners to sell their cars because of this issue, when we may be able to provide a fix.
We just need to do more testing to see if the ash% returns, on the cars that we have done, and work out what diagnostic testers can do this adaptation.
The fact that a GPF ash load adaptation can be done before a static regeneration is a game changer, if you remember the Porsche internal memo says if the ash load level doesn't re set when the OPF regeneration is attempted, then the OPF should be replaced and the vehicle retested.
We know from the data collected from our cars that had new modified filters fitted, the ash % didn't stay at zero for long, and we are monitoring many of those cars at the moment.
So we continue on
Dave
Hi Guys & Girls
Some more information following on from my last post regarding the 3rd car.
The ash measured % level was at 99.61%, with a differential pressure sensor reading of 0.54 hPa, (no pressure) has now been reset to zero.
High Soot values appeared straight away in the measured and calculated readings.
Where did the soot come from, it wasn't there before we did the ash adaptation.
After driving the car for quite a few miles, the cars calculated soot value of 83% came down to zero, and the measured soot value of 52% reduced to 43.9%.
The soot warning light is still on, we are going to do a few more miles to see if it goes off by itself.
If it doesn't we will clear the soot code P2463 and see what happens.
Its really funny that it seems that the measured values of the ash and the soot, are the ones that bring on the warning lights and DTC codes P242F and P2463.
You would expect the calculated readings to be the ones that trigger the fault codes, not the measured.
Regarding the diagnostic tester that have been used to carry out these adaptations we have the following
Autel
Auto logic
Launch
VCDS version 25.3
We will be getting a model number for these testers has we go along, because there are different versions.
Iam arranging to get one of our faulty cars to go into a friend's garage locally, (Knaresborough near Harrogate to carry out the GPF adaptation and provide video information of how the adaptation takes place and show the results before and after.
I was speaking to one of our owners yesterday up north, that had a new modified filter fitted, paid for by Porsche, and the car went out of the their workshop with over 50% of ash still in the system.
This is because at the moment their PWIS tester does not have the adaptation of the GPF and the differential pressure sensor written in to its function menu, they are struggling to reset the ash % correctly in the ECU.
Makes you think if they would have had this function way back in 2019, they wouldn't have needed to bring out the modified GPF, that clearly doesn't fix this Ash issue.
We will push on
Dave
Hi Guys & Girls
I thought it was time to reflect on whats been going on with our GPF fault, and look backwards to when it all started on our forum.
Page 1, May 29th 2023
Mark reported an issue with his GPF to his local Porsche Dealer who informed him that he would have to pay for a new filter because he wasn't driving it correctly.
Page 5, October the 4th, we got involved thinking it was a failed AOS that was causing the oil ash issue.
Page 6, March 30th 2024, we put out a reward of £50.00 to anybody that could send us a dashboard photo of the soot warning light coming on.
Page 7, we increased the reward to £100.00, we also sent out AOS testers to some of our owners with the GPF fault to the check the readings, they all checked out ok.
We never had to pay out the reward money, so we cancelled it.
We rightly believed that a failing AOS was causing the GPF to fill up with Ash, has 90% of ash is caused by burnt engine oil.
We were very wrong to think this way.
Page 9, July 27th 2024 Paul came along with his Boxster 2.5 GTS with the GPF issue, and off we went on another journey.
After months and months in his local Porsche Dealership they replaced all these parts in an attempt to reset the ash % level on his car.
These are the parts replaced below.
2 GPF filters, one new one, and one exchange
AOS
2 differential pressure sensors
DME
Engine removed stripped down looking for signs of internal consumption, none found.
One brand new exchange engine
And finally one new turbo
Unfortunately the ash % didn't go to zero.
Paul changed his car because his Porsche Dealer with all their resources couldn't fix this problem.
So along came the internal memo from Porsche to their Dealers March last year that instructed their Technicians to check for internal oil consumption issues, and checks on the AOS, turbo and the functionality of the OPF differential pressure sensor to make sure everything was ok.
And if everything was ok, then to carry out a regeneration and if the ash % did not reset, they had to replace the filter with a modified part.
Durring our journey we have had 14 of our cars fitted with these modified GPF filters, and 13 of these cars have come back with ash levels way above what they should be.
Thank goodness that Porsche paid for these filters.
We have posted out our concerns that the back pressure check was not mentioned in the internal memo.
Because if it had been, the Dealers would have found no back pressure present which would confirm the none existent differential pressure sensor reading was actually correct.
So a further 39 pages on our forum have been created in hope that Porsche will see that something more needs to be done to fix these cars.
We have given lots and lots of Technical information that clearly shows the this fault has been miss diagnosed from day one.
So to bring us up todate, we are looking at the ash % adaptation of these filters and if we have to create more pages of technical information we will.
Sorry to go on, its been quite a journey, but we are hopefully near to its end.
Fingers crossed
Dave
Like a dog with a bone!
Excellent, we are all behind you and I do not have this problem!
I am disappointed in the way Porsche UK and Porsche Germany have/are performing on this, I personally expected a lot lot better.
It make me appreciate my 2009 987.2 Boxster even more.
Hi Guys & Girls
Some good news, Ive just heard from my chap that had the GPF adaptation and he was testing the car to see if the soot warning light would go out on its own, well it has.
To recap, the GPF was adapted to zero, and immediately the soot values appeared on the screen and the soot warning DTC P2463 was present.
They checked the soot values, and found the following,
K211 soot load calculated was at 83%
K221 soot load measured was at 52%
Remember before the adaptation both soot values were zero and the GPF had not been regenerated.
They carried on driving the car and they checked again, the chap has his own tester, and found the K211 calculated figure was now at zero, but the K221 measured value had gone down to 50%, the light was still on at this point.
A bit more miles, total covered 300 miles, the soot warning light has gone out, the K221 measured value is the same and the best news the K231 oil ash load measured value is STILL ZERO.
This just shows that there is no reason to do a regeneration on these cars when no soot values are recorded when the ash level is at 100%.
When the Dealers follow the memo instructions and carry the regeneration the ash sometimes resets to zero but then comes back if its rechecked again.
So if it doesn't reset they fit a very expensive GPF that doesn't need replacing, and we can prove this because we have all the data of 13 cars that had the modified filters changed and the ash came back very quickly.
We will keep checking this cars ash value, but it looks very promising.
Ive spoken to another one of our 718 owners today who's been told he needs a new GPF filter, obviously I told him not to pay for one, and definitely not sell his car.
Will update you on his progress has we go along.
We will keep pushing, but this is fantastic news
Dave
Hi Dave
That's excellent news and a big step forward to solving this issue, it's amazing how you have got this far when Porsche were unable to do anything about it, except charge customers extortionate amount of money!!
Keep going!!!!
Mark
It’s definitely a software issue that is reading ash level first instead of soot, as we know ash is created when soot is regenerated.
confirmed when the ash is reset to zero and then the soot level becomes readable.
In the past I used to carry out many data gatherings as my time as a master tech so that Jeep/Alfa technical could present the evidence to italy to come up with a software fix. It can take time to implement.
I am convinced this issue is solely a software issue.
Hi Guys &Girls
Some feedback from our trials adapting these GPF filters.
The first car we adapted using a VCDS tester version 25.3, the car was road tested for over 50 miles after the adaptation and the soot calculated was at 0.00%, the soot measured was at 34.51%, and the ASH was 0.00%.
The car was tested again at 628 miles, the soot calculated was at 0.00%, the soot measured was at 3.53%, but unfortunatly the ASH was at 67.06%.
We connected the VCDS tester, but it wouldn't allow us to reset the ASH again.
We then connected a Launch tester to the car, which could read these figures, but it again it wouldn't allow us to do another ASH reset.
I suspect because there was no DTC present and the ASH figure was not high enough to facilitate another reset.
On the second car we used a AUTEL tester, and after 300 miles the soot calculated was at 0.00%, and the soot measured was at 50.20%, and the ASH was 0.00%.
We checked again at 510 miles and found the soot calculated was 1.96%, the soot measured was at 1.96%.
Unfortunatly the ASH was back up to 98.82%, just about the same figure we started with.
Interesting information, the fact that these testers have the facility to do an adaptation is brilliant, bearing in mind the Porsche PWIS tester doesn't have this adaptation function at all.
So its quite obvious that this re setting of the ASH value has always been the issue, and will continue to be until Porsche sorts it out.
I would have thought that this reset of ASH values would be a major requirement on the emission system fitted to these cars.
And also the fact we cannot adapt the differential pressure sensor is another frustration.
Another thought is you would expect to see a DTC code of P0420, or P0430, ( Catalyst system efficiency below threshold) if the GPF filter was indeed blocked.
A blocked GPF filter on these cars would certainly affect the efficiency of the Catalytic Convertor surely.
Ive had two more people contact me this week with GPF issues, and the Dealers are still trying to charge their customers for an expensive part thats not required, we will do our best to stop them.
Iam still waiting for for Porsche Technical to contact me regarding the email I sent to Porsche Stuttgart.
We have so much information that shows these filters are not the cause of this ASH issue, and we can prove it.
My suspicion is that if Porsche Technical could pick a 2019 718 Cayman or Boxster 2.0 or 2.5 which has been Dealer maintained. And they checked the ASH loading data from PDI to present day they would find the the ASH % readings would be very high within the first 2 to 4 years.
This would confirm what the internal Porsche memo said regarding the fitment of a modified OPF filter on December 2019 cars onwards.
They clearly had this ASH issue in the first year that required a new modified filter.
So the lack of an adaptation process then, is causing the same problem now.
We will push on
Dave
Keep going Dave, you will get there!!
Let's hope Porsche Technical do what they say and engage with you, they will then realise this is not going away!!!
160k views(y)
Mark
Thanks Mark,
It would really be great to talk to these guys and share the information we have gathered over the last 3 years.
When you really think about this, its ridiculous that we are in this situation with the technology the manufacturers have at their disposal.
Emission system updates are happening all the time to improve the systems that were introduced years ago, because of the push to clean our air.
What I can't understand is why are 718 2.0, 2.5 cars are being left out, it makes no sence at all.
Dave
Time to re-email Porsche Tech in Germany as weeks have gone by.
Wonder why Porsche thought the 'new design filter' would fix it?
They will have tested it to death before introducing it a The Fix to this issue.
The results must have convinced them the new filter did the job, seems not.
This is a press release from 2018. Shows the pressure Porsche were under at the time. I can remember the sales guy at Porsche saying they couldn't get any new cars so he was extra keen to sell me my (used) Boxster.
  • porsche_is_making_a_model_range_fit_for_the_coming_emission_standards_press_release_06_01_2018...pdf
Thanks Mark,
Dave
Having seen a recent one posted on Facebook I checked the Euro status of the car.
2019 model year cars are classed at Euro 6 AG, am I correct in thinking the majority of these fall in that euro status.
my own car is a 2020 model year that falls under Euro 6 DG which is a stringent stage to Euro 6 AG, as a result the software on these models will be different.
To date I have had no issues in 5000 miles of very spirited driving since I bought the car and it now has a total mileage of 35,000 miles.
a simple check on the car registration will confirm this and helps to build a case.
also build dates of the cars.
Hi Dale
Yes your right,
Enclose a bit more information regarding why the emissions were changed.
Euro 6a/b/c (Ilnitial Stages): Introduced from 2014-2018, these focused on initial laboratory-tested compliance.
• Euro 6d-TEMP (Interim Standard): Introduced in 2017-2019 to introduce Real Driving Emissions (RDE) testing to ensure cars pass emissions tests on the road, not just in a lab.
• Euro 6d (Final/Current Standard): Made mandatory for all new cars in January 2021. It uses stricter RDE2 tests (Real Driving Emissions step 2) for lower NOx emissions, which is crucial for ULEZ compliance.
In summary: The most important distinctions are between petrol and diesel, and between earlier 6b/6c standards and the stricter 6d standard.
Found this info from 2018
Porsche is making a model range fit for the coming emission standards​
01/06/2018
Porsche continues to sell new vehicles in Europe as usual. The Stuttgart-based sports car manufacturer explicitly refutes a report to the contrary by the online edition of the Frankfurter Allgemeine Zeitung.
  • It is true that, currently, it is only possible to order through a Porsche dealership, rather than online. The transition to vehicles being fitted with a gasoline particulate filter (GPF) has resulted in limited
  • configuration options. There is also very high demand.
From September 1, 2018, the Worldwide Harmonized Light Vehicles Test Procedure (WLTP) measurement cycles apply to all new cars in Europe and a new emission standard is also coming into force. Porsche is therefore making its model range fit for the coming emission standards. The introduction of new emissions legislation makes it necessary to transition the model range to use a gasoline particulate filter (GPF) and obtain new type approvals no later than September 1, 2018. As a result, a temporary restriction to the model range is in force. Despite this, in terms of ordering new models – even during the transition period – both prospective and current customers can make use of Porsche Centres.
As part of the transition, there will be a phased introduction of the model derivatives. Starting in September, selected models from the 911 and 718 model lines will be available with a gasoline particulate filter. The 911 4 GTS with all-wheel drive and PDK will also be available in three body shapes from the outset – as a Coupé, Cabriolet and Targa. Alongside the 911 4 GTS derivatives, the new technology for gasoline particulate filters (GPF) will be implemented into the 718 basic and GTS models and then into other model lines.
Porsche is prioritising the transition of model ranges to ensure that the most attractive possible product range remains available to customers. For two-door sports cars – where in some cases the proportion of vehicles featuring automatic gearboxes is over 90 percent – these versions will be introduced to the market particularly quickly.
For all new model launches that fall within the transition phase, all of the initial model variations available with a petrol engine will be fitted with a gasoline particulate filter from the outset. The market introduction of individual derivatives will take place step-by-step, as with a new launch.
Consumption data taking individual vehicle equipment into account
There are a number of challenges which have contributed to the delay: In accordance with the new legislation, vehicle manufacturers will in future have to specify individual consumption data, taking into account the individual vehicle equipment. Calculating this consumption data requires a wide variety of measurements.
“The EU deadlines for WLTP certification, which were brought forward at short notice by a year, are putting us under immense pressure. Our preparations have already been in full swing for more than a year, and we are making good progress”, says CEO Oliver Blume. “Due to a considerable shortage in the availability of test benches, which is affecting all manufacturers, this is currently a huge challenge. We need to prioritize. Nevertheless, we are in favour of more realistic emissions determination.”
Dave
