Cayman 718 GPF Failure
In my view Porsche are unlikely to acknowledge a general issue, especially where the number of GPF replacement instances is so low in terms of production numbers. They will continue to treat them as isolated instances and deal individually. There is nothing they gain from exposing the issue except a small number of satisfied customers and a more general appreciation in the market place. I could not possibly comment on what value they place on that in today's market.
My concern is about going public without factually based certainty as to:
  1. What we know the problem to be
  2. How it can be fixed
  3. How owners should proceed if they are faced with the CEL lighting up
Dave is very close to this point, but we do need some industry support so that it is not supposition. As Dave works with indie specialists as well as OPC's we may soon be able to do that. But we need to be confident in what we publish.
We also need to take into account that exposing an issue significantly affecting this model / year would impact all 718 owners, not just the less than 1% actually affected. It will make no difference to Porsche. That model has been and gone. If you were the owner of one of the affected cars, would you prefer to deal with the issue privately, or have it broadly published, affecting the retail value of your car.
These cars are now six or seven years old. If Porsche can wait until they out of the dealer network they can then forget them and their problems. Think IMS, borescore etc. the whole industry knows of these issues, but I cannot find any statement where Porsche acknowledges them as a weakness except where they have resolved the problem through development. Even in these cases, they accept no responsiblity for the affected cars. (I wonder if any 997 owners have managed to claim for bore score under an extended warranty. This must be a dillemma for Porsche as they try to secure more of the classic market for servicing etc.)
Any info on the cars fitted with the modified filter back in 2019 ish?
The cars went in this issue, OPC changed the filter and the car sent on it's way.
What happened after that though?
Can't imagine an indie taking one of these cars now this cat is out of the bag?
All still very worrying!
The proposed car generated a good report, happy with it overall.
GPF figures were ash 54%. Soot 5%, not sure if that's good or not, and could change quickly i guess too.
Hi Matthew,
Don't forget the Ash % is not real, your filter is not blocked 54%, and your ash code P242F will not come on till it gets between 90 to 100%.
Hopefully by then will will have convinced Porsche to fix this fault.
Hi Guys
Without prejudice
I have just spent a few hours this afternoon looking to see how you calculate how much volume is inside a GPF filter.
The estimated volume of a GPF is calculated by multiplying the engine displacement by a factor of 1.0 to 1.4, ensuring the filter has sufficient capacity to manage exhaust flow and soot loading without excessive backpressure. For example, a 2.0L engine would typically require a GPF volume to be between 2.0L and 2.8 L
Our 2.0 718 vehicles have an engine displacement of 1,988 cm3.
It got me thinking of how is the volume calculated when the GPF is connected to the Catalytic Convertor.
This is a very complex thing to do, Calculating the combined volume in litres of a catalytic converter and a Gasoline Particulate Filter (GPF) involves determining the internal volume of the ceramic substrate (honeycomb) in each component and adding them together.
Plus lots of figures and data, that I have on file.
I then thought let's have a look at our algorithm to see if there is any pointers regarding the volume calculation.
The algorithm designed to cover the ash volume in a Gasoline Particulate Filter (GPF) must calculate a long-term, non-reversible, accumulative value based on engine operating parameters (primarily oil consumption) and, in advanced systems, a correction factor derived from pressure drop changes after regeneration events. Unlike soot, ash is not removed by thermal regeneration. Therefore, the algorithm estimates ash accumulation over the life of the vehicle.
I looked for reference points in our algorithm that mirror the information found on the information above and couldn't find anything that was on our information.
Ash is written into the google algorithm information I have on file, but again it may not be correct
That doesn't mean to say my information is correct, but I was hoping for something to compare.
So I moved on to Google searches regarding any issues with GPF and Catalytic Convertors regarding Ash problems.
I used this search text
Are combined catalytic converter and gpf filters fitted in 2019 more prone to false ash load readings than a single gpf
This is what came back
Yes, combined catalytic converter and Gasoline Particulate Filter (GPF) systems—often referred to as close-coupled or coated GPFs (cGPF)—introduced around 2019 are generally more prone to complex, and potentially false, ash load readings compared to a standalone (uncoated) GPF.
This susceptibility is driven by the physical, thermal, and chemical complexities of integrating a TWC (Three-Way Catalyst) directly into the porous structure of the GPF, which complicates differential pressure-based modeling.
Why Combined Systems (2019) Are More Prone to Misreading
  • Non-Linear Backpressure (Ash vs. Soot): In combined systems, ash accumulates in thin layers and plugs, suppressing deep-bed filtration of soot. This causes non-linear backpressure, making it difficult for the Engine Control Unit (ECU) to differentiate between a high, harmless ash load and a high, dangerous soot load.
  • Reduced Filtering Capacity Monitoring: Because ash reduces the active filter volume and alters the soot distribution towards the front of the filter, the pressure drop sensors can be misled.
  • Thermal and Chemical Interference: The combined unit often works in closer proximity to the engine. Ash, particularly from oil additives, can deposit inside the three-way catalyst coating, reducing the Oxygen Storage Capacity (OSC) and confusing the emission monitoring systems.
  • Sensor Limitations: The differential pressure sensors used for these systems can be affected by high engine bay temperatures and electrical interference, which can cause them to report incorrect values, especially as ash builds up.
Key Differences vs. Single GPF
  • Single GPF (Uncoated/Separate): Typically acts purely as a filter (similar to a diesel DPF but lower capacity), where pressure drop is more directly correlated with soot accumulation, making ash calculation more straightforward.
  • Combined/Coated GPF (2019+): The substrate serves a dual purpose—active emission conversion (chemical) and soot trapping (physical). As ash accumulates, it interferes with both, creating a more "opaque" reading for the ECU.
While these systems are durable, the 2019-era implementation of combined filters often requires more precise, and thus more easily fooled, calibration to distinguish between ash (permanent blockage) and soot (burnable blockage).
Interesting, if we compare our 4.0 GPF engine cars, they don't seem to have have any of our ash reading issues, and the ash loading you see seems to be acceptable for the mileage and age covered.
I then searched for.
What would happen if the calculated volume of a catalytic and gpf was too small, how would it affect ash load readings.
This is what came back.
The calculated volume of a catalytic converter or Gasoline Particulate Filter (GPF) is set too small in the engine control unit (ECU), it creates a mismatch between predicted and actual exhaust flow dynamics. This error primarily manifests as artificially high ash and soot load readings due to incorrect backpressure modeling.
Impact on Ash and Soot Load Readings
  • Falsely Elevated Ash Estimates: The ECU estimates ash and soot mass by correlating measured differential pressure (backpressure) against a stored volume model. If the software "thinks" the filter is smaller than it actually is, it will interpret normal pressure drops as being caused by a more "crowded" filter, leading to an overestimation of ash load.
  • Increased Pressure Sensitivity: A smaller calculated volume implies a higher velocity of exhaust gas through the filter walls for a given flow rate. This causes the system to be overly sensitive to minor pressure changes, resulting in unstable or "noisy" load readings.
  • Premature Regeneration Triggers: Because the ash load is a calculated value used to offset the soot load baseline, an undersized volume model causes the "clean" pressure drop to be interpreted as already partially filled with ash. This forces the vehicle into more frequent and unnecessary regenerations, as the soot mass limit is reached faster in the software's logic.
Performance and Reliability Consequences
  • Reduced Filtration Efficiency Modeling: Ash typically forms a "membrane" that improves filtration. If the volume is under-calculated, the ECU may incorrectly model the filtration efficiency, potentially leading to false-positive emissions faults.
  • Thermal Management Risks: During regeneration, the ECU manages heat based on the expected soot mass. Overestimating the soot/ash load due to a volume error can lead to excessive exhaust temperatures, risking damage to the filter substrate or catalytic washcoat.
  • Fuel Economy Penalty: Constant overestimation of load leads to a permanent backpressure penalty in the software's logic, causing the engine to operate in less efficient modes to compensate for "restricted" exhaust flow that isn't actually restricted.
To resolve these issues, ensure the ECU Adaptations are correctly reset and the specific component volume parameters are verified against the manufacturer's technical specifications.
Are you experiencing specific fault codes (like P242F or P2463) or seeing abnormally high backpressure readings on a diagnostic tool?
The last comments above, abnormally high backpressure readings, and ECU Adaptations are very revelant to our investigations.
On our cars we cannot adapt either the differential pressure sensor, or the GPF, and we have no backpressure.
We certainly need to push on with these backpressure checks, they are the key to unlock this ridiculous situation we are in.
No back pressure means no blocked filter.
Sorry to go on, but all this information backs up the problem we are having with these cars.
Its unacceptable that our 2.0 and 2.5 cars are not the same as our 4.0 cars, regarding Ash management.
Dave
Hi Guys & Girls
Some more info regarding the relationship between Ash and the Ash loading percentage.
Based on research regarding ash accumulation in gasoline particulate filters (GPFs), the maximum ash loading, often representing the end-of-life condition or "full useful life," is typically considered to be in the range of 30 g/L to 50 g/L.
At a loading of 30 grams / Litre, a petrol GPF filter reaches an ash percentage of approximately 94% to 95%.
Our EML light comes on, between 90 to 100% and the message continue to drive will be on the dashboard, with DTC P242F ash load exceeded.
So if the Ash was really present to the point where the GPF needs replacing, how can a soot regeneration get rid of the Ash.
Then sometimes this soot regeneration temporary resets the Ash value to zero, and then it comes back at a lower percentage, usually around 50% ish.
The Ash is not real clearly.
Dave
Hi Guys & Girls
Without prejudice
Following on from my rant about the low differential pressure sensor readings we see on all these cars, when the filter is supposedly blocked.
When you look at the information contained in the internal memo, concerning the checks for possible causes of high ash load.
It clearly says, check the OPF differential pressure sensor for correct functionality ensuring the pipes to the pressure sensor are not blocked or restricted.
So let's talk about functionality.
Checking a differential pressure (DP) sensor for correct functionality involves verifying its electrical signals, testing its physical connections for leaks/blockages, and confirming its output changes appropriately with applied pressure.
Here is a step-by-step guide based on common diagnostic methods:
1. Initial Visual Inspection
  • Check Hoses: Inspect rubber hoses (if applicable) for brittleness, cracks, or soot clogging.
  • Physical Damage: Look for cracked plastic housings, melted insulation, or corrosion on connectors.
  • Wiring: Trace the wiring harness for chafing or damage.
2. Live Data Analysis (Diagnostic Scanner)
  • Connect a diagnostic scan tool (for automotive DPF sensors) and view live data.
  • With the engine off, the differential pressure reading should be at or near zero.
  • If the reading is high while the engine is off, the sensor or circuit is likely faulty.
  • Check for relevant fault codes (e.g., P2453, P2454, P2455).
3. Electrical Test (Multimeter)
Use a multimeter to check the sensor's power supply and signal voltage. Ensure the sensor receives the correct reference voltage (typically 5 volts) and that the signal voltage changes smoothly with pressure variations.
4. Pressure Test (Manometer/Vacuum Pump)
Verify hoses are clear of blockages and use a pressure pump to apply a known pressure. Check the scan tool data to confirm the pressure reading is accurate.
5. Zero-Point Check (Industrial/Transmitter)
For industrial transmitters, equalize pressure across both sides using a 3-way manifold and check that the output is exactly 4mA. A different reading may indicate drift and the need for calibration.
Summary of Fault Signs
Common signs of a faulty DP sensor include constant high or low readings, no response to pressure changes, or erratic data.
If you look at the no2 check, it says with ignition off the sensor should read zero, we have checked lots of these cars and everyone showed the running pressure when the engine wasn't running.
I firmly believe that these checking instructions from Porsche to their Dealers have not been carried out correctly, if they had been, the none existent back pressure would have been picked up, and the inaccurate sensor readings would definitely have been picked up.
 Dave
I have followed this topic for some time and I cannot recall if, of those who have paid for a new “filter” retained the “faulty” item. I’m aware that if repairs are done under warranty, the OPC retains the item.
I’d have loved to have kept my seized engine!
Bill
As I said a few posts back, if you pay for the £9000 filter then the old one is still yours, you have not part exchanged it!
That would allow you to have it examined, but at a cost (may not be that much).
Porsche will snatch back anything to do with this silly issue, so removing the chance to get more facts out of their control and strongly contest their action.
Hi 911Hillclimber
Without prejudice
Unfortunately these GPF filters are exchange, the new part number is 982254400FX, the FX denotes the exchange.
Retail cost of this part is £6,628.00 + vat, and the surcharge price is £757.00+ vat.
You don't need to check the exhaust, because there's nothing wrong with them, the only main fault they could have, is soot leakage, or an internal rattle, if the substrate is insecure, which you could see in the tailpipes.
All the photos I have seen on all the cars I have dealt with, had tailpipes with no soot present at all.
A light grey dusting with a hint of light brown, which is the ash.
This proves that these GPF filters are doing there job, turning the soot into Ash.
Ive said this before, just look at a 981 tailpipe and you will see what I mean.
On Pauls car last year an exchange GPF filter was fitted, which didn't fix the issue.
So a new GPF was fitted, and that didn't fix the ash % that had come back after the first GPF was fitted, as per the instructions on the internal memo, if the regeneration didn't reset the ash, fit a new modified filter.
And has we know, a new engine and turbocharger didn't fix it either.
One of our owners last year did over 10 thousand miles with his warning light and the code P242F coming on and off.
We monitored this car, and he sent me loads of photos of the GPF information along the way, the light off when the % dropped to around 90% ish.
Which proves 100% that these GPF filters are not blocked with ASH, because if they were, you would not be able to drive 10 thousand miles with a blocked exhaust.
This fault which was inherent from the point of manufacture, it was confirmed in detail in the internal memo sent from Porsche to their Dealers in March last year.
So therefore I believe the car is covered under the UK Consumer Rights Act of 2015. The Act states that if the fault is inherent from the start and can be proved to be so by the customer then they have rights under the Act.
We can prove that Porsche knew about this issue within the first year of production, they fitted modified filters to these vehicles post December 2019, this is all in the memo.
They just need to except responsibility for this fault on these cars and deal with it.
Dave
