Suspension Upgrade for 944 S2
- Thread starter herbie75
cheers
I don't doubt you ... but it may be sure to check.
Nick - as far as fitting the original ones goes, it's easy. You need a large allen key and a fairly slim swan-neck ring spanner to get the strut tops off (there are other ways of doing it too.) And a spring compressor. ALWAYS tage GREAT care when using a spring compressor as, if they slip (or fail), the energy released can be extremely destructive. (Don't place any part of yourself in line with the spring when it is compressed.)
Big Dave
Definately SURE...So long as youve got 944S2 / turbo [standard],front struts + NOT the M030 adj jobs [ they have a different diameter spring fitted]...
Ive only just fitted them.... Well last month....
There were the Original Porsche "blue dot" CS front springs...
NOT "spurious" aftermarket jobs.....
Only thing you might have to do ,, is lower the rear, on the spring plate excentric bolts to make the car sit right...
Otherwise itl look like a 1970,s Cortina with a jack up kit fitted....[ Yes i had one of those too....]....[
Will the front want aligning once they are fitted?
Big Dave
ORIGINAL: charles.y
Dave,
What is your verdict of the 968 CS springs over the stock S2 ones on the stock S2 shocks?
A tad stiffer, but not too much....
To be honest. My 968 is sat on "stiffened" KW,s . The S2 is on standard inserts with CS springs..The S2 feels VERY soft by comparison....[
Nick. Yes the front may need alighning . But thats a good thing as the car will feel fab afterwards....
944.343.531.09.904
which I find odd if they are supposed to be 968CS springs, they are black with 3 blue spots on them, can any body advise before I start dismantling my motor!! [
ORIGINAL: charles.y
Any idea where I can download the OEM parts pdf files for the S2 and 968?
and also from the Porsche website in their 'classic' section:
http://www.porsche.com/uk/accessoriesandservice/classic/genuineparts/originalpartscatalogue/originalpartspdfcatalogue/
