Engine Rebuild Finally Underway
I'm very well thanks Rob, missing driving the car but as the saying goes " all good things come to those who wait"..:)
Regarding your rebuild, I note that no one has mentioed the piston grooves, it's important to check that these are not worn if keeping the old pistons when fitting new rings. Also I see that there's a small debate about honing/lapping the bores!..... Well yes you have to be careful when dealing with Alusil and the process for Alusil bores is a little different using different stones and tolerances before final cut. However you do need to hone the bore or it's likely to mean the new rings will not seat properly due to the glaze build up over the 163k miles covered. It doesn't need much and certainly not honing guides, the method mentioned before using scotch pads and paste is about right. If not sure talk to someone like Serdi UK (01895 232215) based in Uxbridge, they certainly know their stuff. Talk to John, Serdi did my block last November, rebored out to 101mm and crank reground for oversize main/rod bearings +0.25mm. They are a very impressive company, dealing with amongst other things F1 engines to ultra fine tolerances. When ready my head will be taken there to have the valves lapped close to F1 standards which are curved instead of angled, gives the best seal possible especially when running high boost. Of course there has to be a slight compromise as these valves need servicing regularly, the answer being to incorporate a slight angle first before the curve.
Oh yes you probably guessed I've been doing a lot of research to obtain the power that I wish for and hopefully this will be the last round of mods,...haha.... Yeh right.......:)
Pete
Hi Mike
Good to see yeh, yes sorry been rather busy with house renovation which is still going on. Car has had to take a back seat for 18 months now but beginning to do some work on her again , she won't be ready for a long time yet though, perhaps another year but when she is she'll certainly rock and won't be troubled by most other cars on the road, not that she was before.....:)
Pete
I know the feeling Pete, if it were not for house renovations I could have a 3.6L 951 with supercharger and 6 speed box....[:)]
you are showing some attractive power/torque numbers, always nice to see the torque slightly ahead[;)] ...am curious to understand your engine mods if that is something you are happy to share.
Good luck with the plasterers[8|]
George
944t
ORIGINAL: George Elliott
George
944t
Hi George
I'm more than happy to share, I'll try to do it later tonight as I'm just leaving the house now for the Ace Cafe meet..:)
Pete
Thanks for that Pete, very interesting, look forward to next phase, my fault for misleading Rob's thread.
Rob, hope your build is going well, very interested in your strategy for Pistons / Rings...
George
944t
A little more progress today inbetween the rain showers. Managed to remove the AOS and the oil cooler housing. Well I say housing. Everything on this car seems to want to fight me!! None of the pipes wanted to shift from the housing after 25 years so I ended up having to remove the housing complete with the lines and the cooler assembly.
Manky cooler that is now nice and clean and all disassembled.
Took that into work with a whole load of other stuff including the sump and took advantage of the parts washer. All now looking spick and span. I then set about removing 25 years worth of gunk from the engine block.
A really nice day today so saw some progress. A good bit of de-gunking of the engine block. AOS refitted. Some vital painting of various bits done. By Andy HairyarseI have to admit. Then Andy and I refitted all the pistons to the car obviously complete with new rings. Thanks for your help Andy came at just the right time. Refitting pistons is so much easier with two [:)]
No worries mate [;)] Was a refreshing change from work! Cant wait for all the shiny, painted, wrapped and red bits all to go on [8D]
Just an update then for those of you that are still folllowing lol. New engine mounts arrived yesterday so they will be going on tomorrow. Re-ringed pistons are now in and the sump is back on with a new gasket. Remind me never to do that job ever again!!! All of the tinware and a lot of the parts I removed are now painted and ready to go back on. So tomorrow the rebuild begins in earnest. Have just finished rebuilding the cylinder head tonight and hopefully it will be on tomorrow.
Check out the valve spring compressor. Don't you jst love homemade tools.
All finished ready for refitting.
Nice one Rob, love the spring compressor and the head cleaned up nice [8D] Got a few errands to run tomorrow but hopefully me and Dan will be around later to give a hand
Looking good Rob, there's nothing better than a little innovation for getting a job done, nice one...:)
Pete
Nice to see it is coming togetgher Rob, a week or so will see you back on the road, good luck with everything.
Regards Jim.
ORIGINAL: jonnyporsche
Head looks nice[:D]is that the kitchen table you're working on? always better than the dining one, saves arguments[:)]
It actually was the old kitchen, some of which now resides in the garage. The cylinder head did reside in the kitchen for a couple of weeks though on the missus' lovely marble table, which later had some sheets of sandpaper glued to it and was used for a spot of DIY resurfacing [;)]
