Cayman 718 GPF Failure
Hi Guys&Girls
Just got this information from one of our friends on the 718 forum.
He has found and purchased a reasonable priced diagnostic tool that can read your oil ash % levels.
Enclose his detailed post for your attention.
I received a £70 ThinkDIag OBD2 scanner yesterday and can confirm that this device will show the GPF ash load etc data on a 718. Device was tested on a MY2022 base 718 2L Cayman.
The menu system on this reader is somewhat obscure. The route to read the GPF data is as follows:
Connect to the ThinkDiag dongle and select 'All Systems Diagnostic'. Let the app connect to the dongle, search for the VIN, confirm the car make/model etc and then:
System Selection
DME (Engine Electronics)
Read Data Stream
K_Catalytic converter
check boxes for the following:
K210_Particulate filter, bank 1 - loading level
K211_Particulate filter, bank 1 - soot load calculated
K221_Particulate filter, bank 1 - soot load measured
K230_Particulate filter, bank 1 - oil ash load calculated
K231_Particulate filter, bank 1 - oil ash load measured
This will return readings for the above. You can then save the readings in a pdf report within the ThinkDiag app.
I had a quick look around the menus to see if this value could be reset via the ThinkDiag. I couldn't see any obvious route to this; however I did note that in the 'Special Functions' section of the DME module there is a menu option to initiate a GPF re-generation. I didnt try this.
At least this way owners can monitor their own K231 ash load values over time rather than having to rely on OPCs to (maybe) give them the data, and at cost.
Thanks again to our friend on the 718 forum
Dave
Hi its me again,
My 718 forum friend has sent some more information regarding this diagnostic tool
ThinkDiag dongle & app are fairly well known in the car world - they're the cheapest way to get a fully bidirectional OBD2 reader and writer that can do many different makes & models. Most people buy them to change factory settings like Start/Stop functionality; this particular one also has fairly extensive data reading / reporting abilities too.
The dongle comes with a 1 year licence for your car manufacturer of choice, chosen at setup time; other manufacturers & periods beyond a year are purchaseable via the app for a few £10s each.
I found one on Amazon and he confirmed it's the same as the one he purchased, enclose snapshot.
Dave
Hi Guys & Girls
Without prejudice
Just a quick update on what we are trying to do today.
And also a re visit to a case I worked on last year.
I have been working with an owner of a 718 2019 for the past month, trying to reverse a Dealer decision to charge the owner 9K to replace a GPF filter the car doesn't need.
We have asked for an additional back pressure check, to confirm the GPF is indeed blocked.
Unfortunately after a month of trying to get this check done we are no further forward.
It seems that the information that Porsche Readings Technical department have at the moment, regarding the fitment of these expensive GPF filters and it not fixing the fault, has not been communicated to their Network.
Surely this miss diagnosis needs to stop, it's upsetting to our owners, it's embarrassing for our dealers, and it should not be happening.
However we did had some good news on Monday for one of our owners, we managed yet again to reverse a decision to charge the owner 9K to fit a new filter, based on the low differential pressure sensor reading present on a supposedly blocked filter.
Going back to Porsche Reading last year I spent 5 months trying to convince them that the low differential pressure sensor reading, contradicted the oil ash % level 100%, and the need to fit a new filter.
Back then the invoice to the customer was over 9K.
We finally convinced them to look again at the GPF report page 42.
After the repair was completed, Porsche Customer Care wrote to the customer and apologised and explained the following.
Whilst Porsche are unaware of an inherent fault with the GPFs on our vehicles.
The fault code which was present durring the investigation on your vehicle did allow the Centre and our Technical and Warranty teams to identify the fault you had experienced to be that of a Manufacturing Defect.
Well it's a shame that the Porsche guy who wrote the internal memo in March confirming that all vehicles with a production date later than December 2019 should already had the modified OPF filter fitted, was not consulted.
Because Porsche have known about this issue for a long time.
So what we need to do, is to stop trying to charge our owners for fitting GPF filters that are not at the moment, fixing this problem.
This needs to communicated out to all the Dealers.
We need to concentrate on the Algorithm / software issue, because we have proven that on all these cars that have had new filters fitted, they are all coming back with the same oil ash % nonsense.
We only have to look at Paul's experience to understand after everything that's been thrown at this fault, the car is still not fixed, and still in the garage.
Going back to our 718 owner with our requests to re check the back pressure, he has told his Service Manager today that I will act on his behalf in trying to reverse the decision to charge him for a filter he doesn't need.
Hopefully he will do the decent thing and ring me.
We have always tried to work with the Porsche Dealers to get this issue sorted, it's just a shame they don't want to work with us.
Sorry to go on, but its about time this fault was fixed.
I have enclosed a copy of a typical GPF report, page 42, for you to see what we see.
The differential pressure sensor reading is K251, and the oil ash measured load % is K231 this puts your light on and causes all this trouble.
By the way, we are now on 59K views, lets hit 60K before the month end.
Dave
Hi Paul
Without prejudice
Great news, 60K views and counting.
Well, some more good news, just had some feedback from one of our members, he's just purchased the Thinkdiag diagnostic tester I mentioned on a previous post.
He's delighted with the information it provides, it shows all the information he needs to check his oil ash % level, soot readings, and the differential pressure sensor information.
Enclose below the information provided by this diagnostic tool.
One question we are always asking is when these filters show a significant measured oil ash % level, anywhere under 100 %, why doesn't this trigger the soot warning light and message to inform the driver to regenerate the filter, as written in the drivers handbook.
The soot warning light and message is controlled by the differential pressure sensor monitoring a soot pressure build up in the GPF filter.
Yet it seems that our Porsche GPF filters with 100% oil ash load measured, have no pressure at all.
Even the modified filter 982 254 400AF doesn't have any pressure when its supposedly blocked with OIL / ASH.
This may explain why the Dealers don't measure for back pressure because of these 3 reasons not to.
1. A separate back pressure check is not part of their guided fault testing when the DTC code P242F is present.
2. A back pressure check is not mentioned in the latest internal repair instructions, that was sent to the dealers on the 3rd of March this year.
3. They also believe that the very low differential pressure sensor reading is always correct on these cars, when they show oil ash at 100%, so why bother.
So it brings us once again to this question.
Why when, they try to reset the oil ash level % to zero, do they sometimes after do more than one regeneration, which uses lots of fuel and the car usually has to have several long road tests to carry out this re set.
If they are successful and get it to zero %, why when then the car is driven further or the following day does it go back up.
If the Oil Ash figure was indeed real, it can't disappear and then come back, by using a soot regeneration method, can it.
It must be some kind of magic, it can sometimes disappear and come back on the original GPF fitted.
And then reappear back in the new modified filter thats just been fitted.
WOW, THATS MAGIC, BUT NOT GOOD MAGIC.
Let's not forget, the soot warning message has never been seen on these faulty cars, if it did come on, the message on the dashboard is different and so is the DTC code.
The only thing that can influence this silliness is SOFTWARE.
I have lots more information coming in on this subject, so please keep viewing this forum to stay up-to-date.
Dave
Hi its me again
Without prejudice
I've just started watching the drama on BBC 1, Death Valley, on Sunday nights.
Its about a retired actor played by Timothy Spall who's character John Chapel is a fictional detective solves case's
Wonder if we could get him to have
a look at our Oil Ash problem, afterall, one minute its there, the next its gone, and blow me, it then comes back on a new filter fitted to the car, and sometimes several filters.
We all like a mystery, but this is getting out of hand.
We have tried lots of times to engage with Porsche Technical, to try and help them get on top of this problem, sadly they will not even speak to our Club, never mind us.
A question I would really like to ask them, is when they started seeing our P242F issues in 2019, and decided to have the filter modified, did they carry out back pressure tests.
Obviously this repair would have been covered under the manufacturer's Warranty at the time.
It's well documented that Porsche changed the oil specification on the 718 GPF cars according to a Google search below.
The Porsche 718 Cayman oil specification changed as a result of the introduction of gasoline particulate filters (GPF) and the adoption of new emission standards in Europe, which occurred in September 2018. This change coincided with the introduction of the Worldwide Harmonized Light Vehicles Test Procedure (WLTP) measurement cycles.
When we started out with this issue, two years ago, the use of the wrong engine oil, was the main reason why Porsche would not cover this expensive repair.
I have heard from several Dealers where they had supposedly put in the wrong engine oil durring service, and they where made to cover the cost of a replacement GPF filter, that we now know may not have been faulty.
It's no wonder that the dealers have gone along with this ridiculous notion, that the wrong engine oil would have caused this issue.
Without confirming back pressure is present, on a suspected blocked exhaust, you run the risk of a major miss diagnosis and replacing a perfectly functioning part.
So here we are a few years on, and Dealers are still blaming the engine oil, and saying that as caused the issue.
Maybe the fact that 90% of ASH deposits in a GPF filter comes from burnt engine oil, could have also clouded their diagnosis.
But lets remember Porsche Technical have been involved with this fault since day one.
They have been more than happy to let the Dealers try and convince their customers that there is no issue with the filters, it was either the wrong oil, or driving style, which they think they can prove, by looking at data on the Val report.
We have come along way, we just need the Technical experts to own up to this miss diagnosis, and sort this issue out.
To many of these cars have been sold, sent to auction, had the GPFs removed, customers dreams shattered, its got to stop.
I apologise if I keep repeating myself on this subject, but its the only way we can keep the pressure on the manufacturer to do something.
Dave
Hi All,
Latest Update -
3 weeks ago a team from Porsche Reading turned up at my OPC to fix my car.
After spending the whole day completing various testing and resets (sorry this is the only detail I have been provided) they apparently manage to obtain a zero reading on the 3rd GPF fitted that must have completed less than 100 miles.
Car was road tested over night and a VAL report completed the following day..
48% full after completing a road test of around 40 to 50 miles …
By this time the Experts ( 🤦🏻‍♂️) from Reading had returned back to their centre of excellence(🤦🏻‍♂️).
My understanding is that following this test result a conversation between Reading and PAG took place and the OPC was asked yet again to inspect for signs of oils on the inlet manifold… (this has been completed so many times I think they have got this task down to McLaren pit stop standards)
And surprisingly no sign of oil…
At this time my car is still in bits awaiting further instructions from the brand …. Don’t hold your breath
I have yet again suggested software as the probable root cause for the umpteenth time over the last 10 months but still the brand chooses not to listen..
I have managed to obtain a couple of pictures of the 2nd GPF that was fitted last Sept that I estimate to have completed less that 1000 miles and it doesn’t appear to look evident of showing signs of being 50% full.. as the previous readings have suggested…(pictures attached)
You can make your own opinion and comment on the pictures..
As of next week my car has been with the brand for 20 weeks (since early Jan 25) after having the 2nd GPF fitted in Sept (24) last year and the guys that designed and built it still can’t fix it ???????
Well another week has gone by and still no news from the Brand on how,if, when they are likely to fix my car.
The way this is going it looks like I am heading for another summer of owning a convertible sport car that I am unable to use it as it’s parked up at an OPC.
It does appear as if we have been abandoned/ignored by the club and the Brand..
Again like Dave has said - not wanting to repeat myself, please at least take this piece of advice..
If you have a post 2019 petrol car next time you have your service completed by the OPC insist on them providing your GPF val readings.. given this is supposed to be a service item they shouldn’t deny you this information.
Hello Paul.
I would strongly suggest going to the motoring press in your situation. I had an issue many years ago when I had a BMW Mini. I've mentioned it before in this thread but in short, Auto Express called BMW for they view on the matter and within weeks engineers from BMW AG were at my local dealership to examine the car and offer a solution to the issue. Needless to say within 2 weeks I had my car back and running perfectly.
Unfortunately sometimes we need to take matters to the next level and if it means exposing the brand we love to it's flaws then that's what we must do.
In your case, I would most definitely be seeking some form of compensation for the money you are paying for a car you aren't driving. Those who are privileged enough to own cars with centre locks due to an issue were handsomely compensated so why not those affected by this problem?
I wish you the best of luck.
Dan
Hi Guys & Girls
Without prejudice
Found this info on a Google search this morning, see below.
We are not suggesting that any of the vehicles we have seen have faulty tailpipe emissions in any way.
On the contrary when you look at the tailpipes they all have had no soot present, and have a light grey deposit.
Which clearly shows the GPF is functioning correctly, in dealing with the soot emissions.
Its only the function of the soot regeneration warning light and warning message, and the oil ash % measured values that doesnt make any sense at all.
We have collected data from over 30 vehicles that we have been involved with, over the last 2 years that have been diagnosed by Dealers and the owners have been told they need new GPF filters.
When we asked for the GPF page 42 diagnostic information on every car, we looked at, it showed on every car that the differential pressure sensor readings were far to low to support the dealer diagnosis of a blocked filter.
Also the calculated oil ash % value K230, always has a 0.00% value which seems questionable.
We recently discovered that these filters were modified by Porsche, and fitted on vehicles after December 2019, the first year of production.
After these new modified GPF filters have been fitted, we have seen high oil / Ash % values come straight back, and the dealers are struggling to re set the new filters to a 0.00% base line.
Which proves beyond any doubt that these filters are not the cause of this fault.
We have recently changed the oil / Ash parameters in the software on one of our vehicles, which suggests its definitely a Software issue.
This vehicle had covered 54K miles, it had an oil ash % of 100%, has had no parts fitted to it, and we are monitoring month by month.
We are still waiting for some more data to come in from the vehicles that are out there with new filters fitted, to get more information regarding this issue.
When we have collected enough data on these faulty vehicles we can then see if this constitutes to a possible GPF control defect, and then possibly take the necessary action.
Dave
Hi Guys & Girls
Without prejudice
Great news, another thousand views, so we are now at 61K.
Thank you all for taking the time to follow our journey, every view counts has we push on, trying to get Porsche to do something about this serious fault on these cars.
I believe, we are making a difference, we had 15K views last September, and we now know alot more about this problem, then we did then.
Porsche Cambridge have just replaced a GPF for one of our members, and with our help and their help he didn't have to pay. The whole process took just over a few weeks.
So thankyou Porsche Cambridge for your help, and hopefully this sets a precedent going forward for any more future replacement GPF filters we encounter.
Dave
Hi Guys & Girls
Without prejudice
Hi Dave,
The GPF traps soot, which burns off once the exhaust is is up to full temperature. The problem can be that tiny, unburnt, particles will remain behind as ash. These will never burn off. The GPF is meant to capture the residual ash, which you would expect could eventually block the GPF. The grey deposits you see in the exhaust could well be ash, suggesting that these GPFs MAY NOT be functioning correctly, possibly explaining your low differential pressure readings. If Porsche knew this, that could explain the use of a software algorithm to predict ash production and throw up a 'return to dealer' warning for investigation (without having an actual plan on what to do next). This begs the question whether or not these GPFs are actually filtering anything. My wife's 2022 petrol BMW is only used on short journeys and there are NO deposits at all on the exhaust pipe and no dash warning lights.
A What Car article (link below) suggests that owners should not be worried about GPF filters blocking on petrol cars.
This is the first thread I visit on this site.
What convinced the OPC above to replace the filter FOC?
Any idea where Auto Express are with an article?
Has PCGB stated they have no response from Porsche UK or Germany?
The tech content of this issue is very interesting, the Customer Care is perplexing, and I thought Porsche were far better than this.
Hi Ian & hillclimber,
Without Prejudice
Thanks for coming back to us,
Regarding your question Ian, concerning the tail pipe emissions on these cars, if you look very closely the light grey deposits have a very slight brownie tinge, which is from from the ash.
Suggesting that the GPF is functioning correctly, which means that passive regeneration on these cars seems to be working ok.
In the last 2 years, looking at all the data from all our cars, we have never seen a soot regeneration warning light and message come on the dashboards, which would instruct the driver to help with an active regeneration process.
This soot regeneration process leaves 2 specific DTC codes as follows
P2463 Particulate filter-soot load high
26740 Particulate filter-regeneration needed
Along with these codes you would see soot values in the calculated K211, and the measured K221 in the region of 50%.
We have this important data on record, it came about after one of our cars had its GPF cleaned with a diesel cleaner that contaminated the filter and set these DTC codes.
Eventually after several road testing outings, using the deacceleration instructions from the drivers handbook, and lots of attempts trying to clear these codes, the codes finally cleared.
And you are right, we should not be worried about our GPF filters blocking up, on vehicles with such low mileages covered.
Regards to your question, hillclimber,
For the last 2 years working with the owners of these faulty cars, it became very obvious very quickly that the low pressure readings from the differential pressure sensors didn't make any sense at all.
On receipt of page 42, the GPF data, a pattern was forming, they all had no back pressure.
The Dealers where insisting these filters were blocked and had to be replaced, so we asked them to look again and contact Porsche Technical for advice, after lots of pushing and shoving, they conceded and have covered the cost to replace these filters F.O.C on every car that was presented to us.
We have gone from this process taking months to get authorisation, to now a matter of weeks.
I think what's significant now, is the new information that was sent to the Dealers in March this year which confirms that Porsche have seen this issue before. It concerns what happens when this DTC P242F, is seen on the dashboard, and the work instructions and checks that have to be carried out, before a new modified GPF is fitted.
We have more information on this document to follow.
David
Hi Guys & Girls
Without prejudice
Further to my last post, I would like to share with you all, this document that was sent out to the Dealers, with information as follows.
I have had this document for a short while, it was left in my post box in a blank envelope with no contact details of the sender.
This document clearly sets out a procedure of what to do if the Particulate filter fault code P242F is logged in the fault memory of your car.
If you look at the last paragraph, it clearly states that all vehicles with a production date later than December 2019, should already have the modified OPF fitted.
All the cars we have seen with this fault, have been pre 2019 December cars.
Its a shame that the Dealers didn't have this information earlier, when trying to explain to their customers how this fault has happened.
Our owners have been told that the wrong engine oil and driving style are the reasons for this GPF failure, and the repair was not covered under the extended warranty, which is another subject on its own.
We are now in a situation that after fitting these modified filters on our cars, we are finding, its not fixed the oil ash % issue, which makes the existence of this information below even worse.
Paul's car is an example of a major miss-diagnosis on this fault, the fact that a simple exhaust back pressure check was not part of the guided fault check on this fault code is absolutely ridiculous.
I will let you all draw you're own conclusions to the existence of this document, and would like to personally thank who ever it was that came to my house and left it in my post box.
Any feedback on this post would be greatly appreciated
Dave
Hi Dave
Without Prejudice
Correct me if I am wrong, but the existence of this document indicates that Porsche knew of this problem on MY2019 cars all along.
Also, I am not technical but in the document it states that in some cases the OPF can be recovered and a OPF regeneration should be attempted.......at 100% ash level???? I thought it was soot that was burnt off during the regeneration not ash!! again please correct me if I am wrong.
It also states that the OPF differential pressure sensor should be checked for correct functionality, would/should this not include a back pressure check? something you (Dave) have been saying for some time and yet the dealers still refuse to do it.
This makes me so angry, I started this thread and I was blamed for the problem on my car, my driving style, I was told not to drive the car if the journey was less than 30 minutes.
I had just had enough of Porsche so ended up selling the car, at a loss, because I could not stomach going through the stress of dealing with them when the EML would inevitably re-appear.
The way Porsche have treated their customers that have been affected by this issue is unacceptable.... shame on you!
I have owned four Porsches but I will never buy another one.
Thank you Dave for all the work you have done on this and it looks to me that you have been right all along.
Mark
Hi Mark,
Without prejudice
Yes your right on all counts, its a real shame that we have come to this, afterall we have tried to support Porsche with this problem by providing valuable data on all the cars we have dealt with.
We have tried to stop the Dealers and Porsche fitting these expensive filters, and we put in steps last year to see if the oil ash % values come back after the new filters were fitted.
Sadly they did, and have, we have had no contact from either a Dealer or Porsche Reading Technical in the last 2 years of this campaign.
We are in a situation that when these cars are out of the dealer network all sorts of things are happening to them.
GPFs removed, GPF deletes, to many cars traded on, resale values going down, owners selling cars, when they shouldn't need to, is ridiculous and it should not be happening to our cars.
There is nothing wrong with these GPF filters, you only have to look at the tailpipes, passive and active regeneration is working, even without the soot warning light coming on and driver intervention.
Compare the tailpipe colour with let's say a 981, and you will see how good these 718 cars are.
We will not stop till we have an acknowledgement from Porsche that they are going to look into this further, the software would be a good place to start.
Dave
Dave. Great work and I admire you tenacity.
Could I ask how you think Porsche will finally admit that there is an issue and get this sorted. There is lots of talk of doing this and doing that but nothing that is productive from Porsche. I have said this many times but the only way that anything will get done is if issues like this are raised within the wider community by stating a case with the Motoring Ombudsman or motoring press. I really don't see what the hold back is with doing either or both of these?
Porsche are obviously not interested in looking after customers with this issue so why should those affected or have been affected be concerned about going further? I really don't get it. Sadly views to do not get results especially on this thread as I believe it can only be viewed by members. I spoke to my service advisor the other day and asked if they'd read the article in PP on the GPF issue. They said they don't even see the magazine as it only goes to Dealer Principles.
I commend your hard work, I really do, but you need to take this further to get the best results. Speak to the motoring press, and I don't mean PP. You're best placed to do so with your technical knowledge and I'm sure that it will bring the results everyone is hoping for.
Dan
Hi Dan
Thanks for your input
Without prejudice
A thousand more views on our forum, after a few recent posts.
We are now at 64K.
Over the next few months we have lots more cars going back in to the Dealers for oil ash % checks to be carried out, after the new modified filters have been fitted.
Not that we need anymore information to confirm these modified filters seem not to have fixed this fault.
But the more data we have, the more of a chance we have in pushing Porsche to get a hold of this problem.
I do believe views count, they are showing clearly there is lots of interest in our campaign.
Hopefully the release of this document acknowledges the responsibility of the manufacturer to commit to a fix.
We now have sufficient information and cars to challenge the GPF control function on these cars, and we are putting together a case on the basis that the oil ash% and soot warning function on the cars we have looked at, doesn't look right.
Fingers crossed.
Dave
