Hi Tony
A bit more differential pressure sensor information to back up our investigations regarding the checking of this very important sensor.
When these sensors fault, they stop showing a zero reading, when the ignition is on, engine off.
All these photos were taken from the same car, this car came into the workshop with the warning light on with DTC code P242F oil ash load measured at 100% K231.
We are looking at the differential pressure current value sensor reading K251.
The first photo shows a reading taken with ignition on, engine off. 13.43 hPa (this should be zero)
The second photo shows the idle reading of 22.22 hPa, ( this is far to high)
The third photo shows the reading of the new sensor fitted with ignition on 0.50 hPa.
The fourth photo shows the new sensor reading at idle 9.29 hPa
And the fifth photo shows the sensor reading after a regeneration was carried out to clear the fault code P242F, 0.33 hPa.
You will see the ash measured reading K231 is now at 0.00%.
The sixth photo shows two sensors, the old sensor is top sensor you can see the age of this sensor VW AG 38/18 TN3, 38th week in 2018, the original sensor fitted at the factory.
It will be interesting to see how old you sensor is
Dave
Dave
