I think so, didn't you say this another time? I use imgur.com for hosting them, perhaps your browser or other software is blocking access?Am I the only one who cannot see the pictures?
Another 944 Turbo Engine Rebuild Thread
- Thread starter dlknight
I can see them fine Thom.
Must be getting close to the nerve jangling first key turn?
You don't want to bothering with things like gearboxes and exhausts until you know it runs properly.
LOL - still at least 4 weeks I reckon, had to do some evening work to get to the point I'm at now.
Still some paint work to do on the rear valance and exhaust back box mount (basically redoing the poor work that the useless car restorer did).
I know what you mean but I'm going to wait until the gearbox and exhaust is fitted before firing the engine. I may turn it over on the starter though before then to build up some oil pressure.
Fixed it looks like some browsers don't like the linking back to imgur.com (or imgur.com are blocking the pictures in some scenarios if they think it has been hosted on a webpage and not a bulletin board or forum).I can see the pictures if I open them one by one in a new window directly from the hosting website but the embedding on the forum does not work for me regardless of the browser used. Nevermind...
must be BrexitStill doesn't work, but nevermind. Sorry for disrupting your great thread ...![]()
Crikey - getting behind on my updates again!
Continuing the story from last time, I had to make a repair on the wiring loom, for the knock sensor wiring. Found some cheap VW / Audi electrical connectors with wires for splicing into an existing loom on eBay.
Made the repair and sleeved each individual cable and the main wire with some heat shrink.
I then continued assembling the engine ancillaries including the air conditioning pump, power steering pump, and intake manifold.
Next, I connected up the wiring loom and ECUs inside the car and reconnected my aftermarket boost gauge.
Refitted the turbo water pump with a new silicon hose and some heat proof sleeving.
Picked up the rear engine protection plate, which I'd been looking for some time, pretty good deal and in good condition (just needs some cleaning, possibly vapour blasting).
Ordered some bits from various places including Torques (on eBay) and the UK distributor for Cohline hoses (for the power steering hose - low pressure). Made up a new power steering reservoir to cooler hose using a brass 90-degree bend. Finished the cylinder head steam vent kit and spliced it into the radiator to coolant reservoir hose.
I then made up a fuel damper hose using braided rubber hose and the 16mm metric 90-degree fittings (this will possibly be up for sale soon as I'm making a braided PTFE one instead).
Next up was to refit the air conditioning system with a new condensor and receiver / dryer (including new o-rings).
New battery ground cable from eBay 35mm2 (240 amp) and 300mm long for £7.49, and appears to be made with quality cable.
New front radiator duct installed.
Front bumper installed!!! - had to modify the slit for the towing eye mount to fit my new custom-made mount. The paint job I had done back in 2014/5 looks rubbish; I masked the cutting area with tape and carefully cut the slit wider with a Dremel. When pulling the tape off some of the paint came off with the tape! so the prep must have been rubbish. Might touch it up for now so it blends in at a distance.
Then the torque tube was installed into the clutch / flywheel, lots of wriggling around until I realised, I hadn't measured how far the end of the shaft sits from the rear bellhousing as per Porsche specification 49.5mm +- 0.5mm. Mounting bolts left loose as per Porsche manual until the transmission is installed.
I got a custom clutch hose made up by HEL, M12 x 1.00 90-degree one end and M12 1.00 straight on the other end, 100cm long. Fits great and allowed me to bleed the clutch slave cylinder whilst it rested on the top of the wheel arch!
I sanded down the batwing, painted it with some plastic primer, and then some black trim paint from Halfords. Came out pretty well and then installed.
New sticker from Classic Stickers in France for the coolant bleed instructions (sits on the intercooler feed pipe).
Picture of the old sticker for reference.
Sent my injectors off to Mr Injector UK for servicing, they did an amazing job and came back looking brand new. They would probably have been fine though as the pre-service testing showed they were in very good condition.
BEFORE
AFTER
Some recent pictures, intercooler piping and air filter snorkel is now installed (need to take another picture).
BEFORE
AFTER
Kongsodoken
Looks really good -excellent work
Thanks Folks, managed to turn the car around on my own over the weekend and get it back on the axle stands. Need to paint the rear exhaust hanger and valance. Then refit the fuel tank, transmission, exhaust, test fuel pressure, test cooling system for leaks, spin it over to build oil pressure etc (without fuel).
