On my new 992.2GTS I purchased the front and rear car dash cam option and decided fit it myself rather than pay over £500 to have it fitted. The new cars now come with the prewired option, although you still have to purchase the harnesses for both cameras and remove some facias to locate the connectors. It is a bit fiddly to fit but there are good informations available on the web. After fitting you still have to go into dealer mode to set up the camera for the type of battery for the car and the duration the radar is on, maximum 1 hour. I struggled a bit to find how to go into dealer mode for the camera.
To activate dealer mode:
Remove SD card
Plug camera backing the mount after removing it it.
Hold the power button down until you hear two audible beeps.
Both lights will come on the read and the yellow
Connect to your Dashcam using a lap top or iPad using the WIFI on 324B6D or similar
Type in 192.168.1.1/diagnostics on your browser, and bingo you, just follow then the instructions on the screen.
During normal operation and trying to access the camera files from the Dashcam software on your phone, disable bluetooth on your phone ,otherwise the software keeps trying to connect to the car internal Porsche network due to apple car play.
Remove SD card
