Noise from 991.1 GT3 PDK Gear Shifter
911-lee
Does anyone know what this mechanical grinding noise coming from the gear shifter area on my 991.1 GT3 is?
It only seems to happen when the engine is idling and in P although not every time and the noise stops when you select D, or sometimes on it's own. I know the PDK in the GT3 is noisy but this doesn't seem like a normal GT3 noise.
The car has been back into a Porsche OPC under warranty who have said it's normal but I've had advice from other GT3 owners that it isn't and has been fixed on other cars.
I agree with Dan that it doesn’t sound right Lee. Most likely it’s a rattle from the transmission being transmitted into the cabin by the cable linkage between the selector and the actuator on the transmission.
Apparently, when P is selected a spring-loaded pin [the parking pawl] is moved into position to engage a specially designed toothed wheel mounted on the output shaft of the transmission. Maybe the pawl isn’t engaging completely and it’s this which is causing the rattle when the engine is idling? Hopefully there’s some adjustment available in the linkage/actuator, but whatever is the case your dealer needs to look into this more closely instead of fobbing you off with the usual excuse that: “They all do that sir”.
Just my tuppence worth of course.😀
Thanks Jeff, they weren’t having any of it the other day when I spoke to them.
It would be great if I could show evidence of the same issue on another car that had been fixed by an OPC.
If that’s the case Lee, maybe Cambridge can demonstrate what you’re experiencing on one or more of the numerous PDK-equipped cars they have for sale!
Just out of interest, does the sound go away if you put light forward or back pressure on the selector from the P-position? If so then that could confirm my suggestion that play in the selection mechanism is a contributor.
I’d keep pestering Cambridge. Probably they can’t be bothered arguing the toss with the Extended Warranty insurers to pay for some diagnosis time.🙄
The service centre for Cambridge isn’t on the same site as the dealership, they’re quite some distance apart.
The cars due back to me on Monday so I’ll try and do some more investigating myself when I’m next out in it. It’s frustrating as it doesn’t happen all the time so isn’t readily seen/heard.
Lee,
I can assure you that there is a service facility at the refurbished Cambridge centre in Harston [I had a tour of the facility a little while ago with Region 10], with an overflow facility including the body shop in Royston.
Good idea to do some investigation yourself to see if you can narrow-down a potential source before going back to Cambridge with any findings.
Good luck!🤞
Lee,
Good luck!🤞
Jeff,
I can only go on where I was told the car was going when it was collected and the tracker location.
