Just checking in chaps....this looks worth a punt?
- Thread starter bennyboy
pauljmcnulty
Copperman05
Edd
pauljmcnulty
ORIGINAL: Copperman05
Dont think the engine is the issue, RPM have built a few S2 track toys. For me its just the general look of the car, its too blue! Ugly IMO
Edd
I agree about the blue, but a few ££s on paint isn't a deal-breaker. I just can't see there being much of a market for any modified cars built around an S2, and if you talk to anyone who's built a track-focussed S2 I can't believe they'd agree it's an easy car to sell?
Even totally original S2s in incredibly good condition are hard to shift for that money, and they are the pick of the "untouched" 944 range. You see plenty of pretty decent track-focussed turbos not fetching much more, and that has to be where the sensible money would go?
Copperman05
Edd
Neil Haughey
As a track day car then fine, a bit OTT, and it was great for Mark to race his turbo last year but hardly anyone races a 944 turbo in this country any more yet there are enough S2 and 968 race cars out there to pack a grid just based on those cars.
Neil Haughey
I would go as far to say that you could get 95% of the performance of a track focused 968 club sport for a fraction of the price using a similarly focused 944 S2.
Edd
All the evidence from the clubs championship supports that assertion. The difference tends to range from as little as half a second a lap up to about 2 seconds a lap when comparing the quickest in each at different tracks. As a percentage the difference is a lot less than 5%. I wouldn't quite say the build cost is a fraction as really the value of the donor car is only a very small part of the total cost to build a race car from the ground up and this is sort of reflected in sale values as there is only a couple to few grand or so difference between an S2 and 968 race car on the market.
btw what is a rough average take home weekly wage in the UK? 500gbp - 1000gbp?
Cambridge Punts currently selling for approx £3K[&:]
pauljmcnulty
Average salary is a bit over £20K. Take-home on that would be £400 a week I'd guess?
Not bad underneath, some rust inside sills. Sill covers not well refitted after repairs.
Gearbox has more oil over it than my 250K mile one
Inside is partly stripped but very untidy, cracked dash, speaker holes in doors, bits missing etc and the sunroof - couldn't work out if it was still operating or not - but the interior of it has been removed (probably due to the fitted cage) but left with blue plastic sheet! The seats are nice as is the steering wheel, both Sparco, fire extinguisher is out of date, no gear lever gaitor and the insert is held in with electricians tape.
Engine starts well, is pretty clean, slight oil leak and sounds ok - not sure about belts etc, but would think have been done in the last couple of years.
Suspension is new looking Spax all-round, strut brace, and huge ARB! Looks quite low but still has 944 wishbone mounts.
Rear bottom mounts look odd, bolts are in fully but shock mount is free to move 10mm each way on the bolts?
No undertray, splitter is normal fibreglass.
Some nice bits on a decent shell, which has had some work done on it.
Did suggest £2.5k was more like it........
ORIGINAL: jdpef356
Im off into Cambridge to buy a punt following comments made by Mike after viewing[
I agree with Mcnulters though, a track Turbo would be easier to sell. It's not purporting itself to be a race car, they are a different league, its simply a home converted track car. I've tracked my S2 many a time and it was the sole reason I bought the Turbo - it gets frustrating having to keep moving over on the straights when you have an underpowered engine in a great 944 chassis
944 man
ORIGINAL: 333pg333
Wow, if it's in good nik I can't see the problem. That's cheap for what it is. Well to put it in context $6k would be cheap out here for that and based on similar average wages in terms of a number.
£26,000 per annum / £498:63 per week gross. Our exchange rate had dropped from about three Aus$ to the £, to two Aus$, but 944s still seem to be worth twice as much in Australia as they are here. Due to supply I presume?
Perhaps RPM did more modifications but £10-12,000 buys a lot of goodies.
