Help Needed - Warranty 'Void'
lee.davies
Hi folks,
I am hoping someone can help me. I recently purchased a Porsche 991.2 Turbo S from Porsche Mid-Sussex (April 23').
I have recently installed a 'Quick Silver Exhaust and De-Cat through a 'authorised quick silver installer' I have travelled less that 200 miles in the car since the install. It is currently in Porsche Dealership and they are not honouring the warranty as the "ECU has been tampered with".
Any advise or previous experience would be greatly appreciated.
Thank you in advance for your time.
Best regards,
Lee.
Hi Lee,
Since you’ve purchase your car from an approved Porsche dealer you’ll have received the Porsche Extended Warranty, for which there are explicit T&Cs, one of which is that the vehicle must remain in standard condition. Unfortunately I fear that by fitting aftermarket exhaust system components you will have invalidated your warranty.
Note that the Extended Warranty is insurance based and is only administered by Porsche, so they can only abide by the insurance company’s conditions.
Hope you manage to get something sorted.
Good luck but i fear you have lost your warranty, even if you reverse the install and "reflash" the ECU
I suspect 'authorised quick silver installer' refers to the installer being authorised by Quick Silver...not be Porsche
Presumably the decat means it fails the "Construction and Use" regs and may also fail its next MoT
Fitment of the exhaust and decat pipe wouldn't, in itself, have included an ECU reflash, would it? Accepted that physical changes have been made but I can't see why they wouldn't be reversible without an electronic trace being left behind? Or does the Quicksilver package include a reflash element?
And, in any event, the wording of the Approved Warranty makes it clear that warranty cover can only be withheld when the fault is caused by the fitment of non-OE parts. The warranty cannot be voided in whole - only issues related to or caused by the aftermarket fit are excluded. Which begs the question: what is the fault that is being investigated?
James
Here you go - attached as an image (I hope).
Operative wording being ".. to the extent that the defect arises from..."
James
mmm - i've seen the argument that , where the exhaust has been modified, a cooling, brake or transmission issue etc were rejected as the parameters had changed. Car performs at a higher standard due to more bhp, putting more strain on the "downstream" components...
Given that some non-servicable items (eg engine mounts, GPF, are being rejected under the "wear and tear" clauses.. the OP could be in for a long debate....
Hi Lee,
what problem did you have to take it to the OPC for?
lee.davies said:
Hi folks,
Best regards,
Lee.
