Grills and Warranty
- Thread starter tscaptain
andycarter
Are they an easy fit or let Zunsport fit them? Any idea of cost for fitting?
richardjjs1
Are these the best on the market?
[link]https://www.youtube.com/watch?v=XkUZzU-Ymg4[/url]
i got the three grills. Zunsport provided amazing service and they took about 30 minutes to fit using a screwdriver to flick the clips over. All within 48 hours of placing my order on line. Very satisfied.
Hi JohnJohnCR said:I fitted them to my Cayman GTS earlier this year and they have now been on for over 10,000 miles and saved a lot of rubbish from the intakes. I am booked in with Teesside for my 111 check but will now get them to decide on the grills before they start, as they are not coming off. I will go elsewhere for my warranty if necessary.
I’m currently in dialogue with service at Teeside regarding fitting these and impact on warranty on my 718 Cayman. They are in dialogue with customer service / warranty regarding this having previously said ”no”. They have said that if I had fitted them they would send an online ticket to Germany to review. They have sent Germany the web link to the specific grilles on the zunsport site
Where else will you go for warranty - different OPC or non Porsche?
Sorry - is your GTS a 718? If so, do any of the side grilles require drilling to fit - the kit suggests they are supplied with a number of screws....I thought they were all clipsJohnCR said:I fitted them to my Cayman GTS earlier this year and they have now been on for over 10,000 miles and saved a lot of rubbish from the intakes. I am booked in with Teesside for my 111 check but will now get them to decide on the grills before they start, as they are not coming off. I will go elsewhere for my warranty if necessary.
gtipirelli
also, do you have to take anything apart on the car or is it simply, get down on your knees and clip the grilles in behind the existing plastic in front of the radiators
thanks
PHB1969 said:Sorry - is your GTS a 718? If so, do any of the side grilles require drilling to fit - the kit suggests they are supplied with a number of screws....I thought they were all clipsJohnCR said:I fitted them to my Cayman GTS earlier this year and they have now been on for over 10,000 miles and saved a lot of rubbish from the intakes. I am booked in with Teesside for my 111 check but will now get them to decide on the grills before they start, as they are not coming off. I will go elsewhere for my warranty if necessary.
Another complication has cropped up that mine is going in for an extended warranty check, which is essentially an insurance policy, rather than the manufacturers warranty that you get for the first three years. They may have different rules - we’ll see.
There are a number of alternatives on the market. I am only looking for cover on the big ticket items - engine and gearbox.
Phil Evans
Just got a reply from Porsche Germany regarding these Grilles and the effect on Warranty (and also regarding replacing exhaust bolts with stainless ones), in short grilles are verboten, but the bolts are acceptable!
‘The Cayman, as a more ‘standard’ vehicle with far less track use has the smaller air intakes since the focus is on the CD value (coefficient of drag). With the GT vehicles, the focus is more on track use with corresponding raised danger of gravel bed/stones on the cooling units. Therefore with the GT vehicles the CD value is not as good as with the Cayman due to the larger air intakes which are protected by grids. The air loss through the grilles are compensated by the larger air inlets. Installation of grids on the Cayman are not permitted under the Porsche Warranty as there is a risk of overheating.
In reference to your second email regarding the bolts, should the customer wish to install other bolts this will have no effect on the warranty of the vehicle.’
With all the different reports on this forum it sounds like many OPCs may be turning a blind eye to this, so it's all a matter of luck! (or just remove them prior to warranty renewal!)
i will let you know when I get my answer.
Gwsinclair said:Afternoon all.
PAG ZERO1
https://recall.porsche.com/prod/pag/vinrecalllookup.nsf/VIN?ReadForm&c=gb
