blade7
Well-known member
You'll need all those bits to extend the front of the shack, or the front end of your car will be turning pink by AugustYou are very welcome to take those bits to a tip for me...![]()
You'll need all those bits to extend the front of the shack, or the front end of your car will be turning pink by August.
The car looks beautiful. Fantastic! I'll keep mine covered up I think...
Good advice about gravel...pea gravel also gets stuck in the tyres, so 20mm stuff is better, or Type 1 stone. Avoid Cotswold gravel...lovely colour but turns to dust when driven on. Spring job is to gravel my parking area...an 800kg bag should do it.
Howay man, you didn’t even realise you had the bigger brakes until Thom pointed it out for youProbably a good plan, considering the diddy S2 brakes![]()
Hi Pete,
What kind of paint was used on your car?
Was it water based?
