The 997 was launched in September 2004 in Carrera and Carrera S forms. The Carrera has a 321bhp 3.6-litre water-cooled version of the flat-six from the 996, whilst the 'S' had a 3.8-litre version of the same engine developing 350bhp. Later, models were expanded to include other variants, but the focus is on these two.
There were 3 times as many 'S' versions sold as the regular Carrera but the 3.6 engine model has serious grunt and would be ideal for novice 911 Porsche owners or those not familiar with high performance sports car motoring. It'll be a car that's a little cheaper to acquire and run too.
2005 Carrerra 2 'S'
The 'S' model was produced with the new PASM system and offers switchable adaptive damping as standard. Both models have variable-ratio steering and PSM stability control. The Sports Chrono package was an option that provides a dash-mounted stopwatch and, more importantly, a Sport button with improved throttle control and damping. There was also a factory fitted Sports chassis option available which lowered the ride height by 20mm and provided a limited-slip differential. Gearbox choices were a new six-speed manual or the old-time five-speed Tiptronic auto.
Improvements in the chassis elements were noticeable when switching the PASM to its firmer setting, whilst pressing the Sport button sharpened the vehicle's dynamics. Porsche Communication Management (PCM) is another worthwhile option to look out for, combining an improved hi-fi system with factory-fitted satnav (although you'll find this rather outmoded compared to the latest offerings). All-wheel-drive Carrera 4's and 4 'S's arrived in November 2005, but some drivers prefer the 2WD versions, as they seem sharper and are lighter. The Turbo and GT3 derivatives were made available in 2006, also Targas and Cabriolet variants. The Gen 1 Turbo retained the Metzger designed dry-sumped flat 6 engine, originally manufactured for the GT1 Le Mans race car and many purists mourned its passing, which was necessary due to new emission regulations and rising manufacturing costs, when the Gen 2 Turbos were launched.
Gen 2 arrived for the 2009 model-year and the engine was almost completely revised with direct injection and VarioCam Plus valve gear. Power was now up to 380bhp for the Carrera S and this raised the top speed to 186mph with a 4 second 0-60 time. Transmission was also transformed with the arrival of the PDK twin-clutch auto gearbox as an option.
If the budget is below £25K, you're looking at a Gen 1 997 and you would be well advised to buy one from a dependable source or, if buying privately, having an independent expert carry out a thorough inspection. The charge is likely to be around £350 for a full work-out.
An official Porsche warranty is available for cars up to 15 years old or 125k miles whichever comes sooner, but it needs to be submitted for 111 point check to a Porsche Centre. The current cost of this is £180+VAT. The check can only be commissioned if you have owned it for a 90 days or more. So ask your seller to get it done as part of your purchase agreement. The warranty is around £1100 for the year (£1920 for 2 years), excluding the cost of the inspection. The vehicle will also need to be in completely original factory spec in order to comply with the terms of the policy.
Regards,
Clive.
Regards,
Clive.
