Porsche Tonbridge just started adding to my car this afternoon.
what is a diversity control box ?Seanmk690 said:Dear Castorman,
Thank you for your write up, I purchased one last week nd have been trying to fit it. I have been led to believe that the small black wire with the gold end is a bypass for the amplified aerial(drivers door pillar) the wire with the blue ends is to bypass the diversity control box in the passenger footwell. Obviously you have not used either. Can you tell Me what connector you have connected to the white connector of the FM/DAB splitter(silver box left side of shelf) top photo. Are you getting the full range of DAB FM/AM radio, I’m not getting my Radio DAB or otherwise, but then I have fitted both the bypass’.
Just one observation about your write up the PCCM plus should have been placed into the Black plastic frame before assembly of the side plates and shelf.
Many thanks in advance.
Sean
Jon_Dakeyne said:Presumably having the new upgrade fitted sorts out the wrong date and time issue a few of us are experiencing now our cars are older. Can anyone confirm if this is the case? Really asking to find out if the date/time issue is indeed from the CDR2 unit. Thanks.
I know people who have tried fitting a used PCM2, but with limited success by coding. It seems like you need to get the unit decoded to remove the protection. Someone like DND Services or Maple Audio may be able to help with that. Personally, I see little benefit of putting a 20+ year old navigation system in a car, just because it was original fitment. Your experience with PCCM+ has highlighted how out of date the old system was.eddieterry said:Loving my new Pccm+ - Stunning bit of kit.
I want to sell my old PCM 2 but don’t have any code to go with it. Do you still need code if putting into a different 996. If so is that something a Porsche Centre can do for the buyer if I don’t have the code. I would think it would need to be coded to a new chassis number anyway. Help needed !! Thanks in advance.
