wheel fitment
- Thread starter texpis
ukmastiff
ChasR
Not quite Mas. Paul Smith and I both have S2s on Boxster wheels with no issues (no wheels outside the car, no rubbing inside etc.). His 951S is also on Boxster wheels. The issue I think you are referring to are with the 220 Turbos (yours had 16" Teledials right) which shared its offset with the earlier cars.ORIGINAL: ukmastiff Be very weary of Boxster wheels on an S2. Im not sayig none will fit as a boxster can have many wheels BUT the S2 and Turbo have quite a different fit/offset because of the brakes. Your average 16" Boxster alloys ( like the perfect refurbed set I bought) won't fit an S2 or a Turbo but will normally fit any other late 944 such as a 2.5 lux/2.7 lux or an S. Also are you not quoting tyre sizes there not wheels sizes ? With 17" you tend to be a bit better on the brake clearance but still check the offset. Regards Mas
944 man
944 man
They will not fit your car, if the offsets mentioned are correct. The vendor is either ignorant or simply misleading you to effect a sale.ORIGINAL: 944 man The wheels referred to here wont fit a Boxster, let alone an S2! [] To fit a 1987 model year onwards car, then theyd need an offset of about 60mm at the front and an ideal of 78mm at the rear. Youd probably get away with 60mms at the rear though, as theyre not particularly sensitive to rear offset...
How refreshing! Someone who thinks the same way as me on this matter! (And something that edh and I agree on! [ORIGINAL: edh of course no-one has mentioned the most important thing - Boxster wheels look wrong on 944's [:'(]
