924Srr27l
When does a Modified car begin to add value ?
The Singer 911 is a Scenerio where a stock classic car is highly modified in many areas
to a high standard and performance upgrade package and then the costs are high as is the end Resale Value.
Could the same be done / had with a 924 ?
Generally any car not to mention a Porsche doesn't increase in Value when it's modified from standard,
If the wheels are changed, a different Exhaust fitted or all the brake and fuel lines replaced etc..the costs to
the owner do not usually increase the car's value?.
However if a car is restored and this can also be done in various lengths it's value can be recognised for the
expenditure and the amount can go up dependent on how extensive the work / Restoration is.
How much in this current market would a 1987 924S be worth if it was Fully stripped, rebuilt and Restored and
not Modified but left standard £25,000 ?
How much would an extensively modified car be valued at ? which has NOT got standard parts fitted or Porsche parts
More or less?
R
More or less?
R
