robwright
Is this in relation to your car Mike? A picture may help [&:] The only line I am aware that fits to the actual throttle body would be the one from the fuel vapour purge system if fitted? All the vacuum lines originate from the inlet manifold. Fuel damper and regulator and dump valve if you have a Turbo. Going in the other direction it goees to the vacuum resevoir via a check valve and to the HVAC unit for the solenoid valves and heater control valve.
