Transmission mount? 1989 8v
martin.vesty
So what are the recommendations for replacing a worn out mount- assuming this is the source of horrible juddering in reverse on my slightly inclined driveway?
I’ve checked the clutch measurement which is 22-23mm and feeling the transmission it does wobble side to side on the mount and up and down under my limited force.
I’ve seen the great NC944er video and may attempt myself but as it’s going to a specialist garage on Monday anyway, I may just ask them to fit it.
I’ve seen OE mounts, fixed mounts (design 911) and I’m sure there are other options. Which are best?
I've got a 9 products semi solid mount. It greatly reduces the movement of the gearbox. It's a lovely piece of kit.
Thanks - that looks the same as the 911 product I looked at.
Does it not increase noise from the transmission at all?
Seems that the Indie Specialist prefers to use the OE part for this so I'll probably stick with that if they can source the part and complete the job whilst in next week.
It does not increase the noise from my transmission, it still has rubber mounts (a lot less rubber than OEM), just a much more robust solution with less slop.
A fully solid one however would increase noise and vibration.
Thanks again for the feedback Stuart.
I discussed at the garage and they agreed to go for the semi-solid mount as an upgrade over the OE. Should be getting the car back later today all being well after this and the Cam tower gasket have been done.
Will let you know my impression of any difference in feel & gear change :)
Wow, just fetched the car back from Flat6 @ Boroughbridge North Yorks. What a transformation with the semi solid mount supplied Rohler by Design 911. Such a positive gear change feel and I can actually hear the linkage and gear change. There is more gearbox sound but no vibration. The box feels more like my old Hewland Formula Ford gear change and sounds just wonderful.
I have to say a great job done on my three items at Flat6 by Richard. They also gave the car a post purchase inspection as well as tweaking a few bits for me.
Nice result! I reinforced mine with epoxy a few years ago, I've read that some have converted the mount back to the older style which had one mount either side of the transmission. I wonder what the reason was behind the new single mount design.
I’m not living this semi solid Rohler mount and want to refit an OE mount?.
The Rohler is just far too noisy.
Does anyone have two of the Transmission Stop brackets I can have?
94437507901
The garage that fitted it for me gave me the old mount but not these two pieces and their used metal has gone!
Discontinued part?
I may have but will be next week before I can check.
I may be interested in your semi solid mount too (NVH should be my car’s initials) - and I’m just up the road in Newcastle.
Hi Martin. What happened from you being over the moon with it to can't live with it?
Hi Stuart,
After the novelty wore off of hearing the gearbox and diff I decided to go back to a new OE mount. It’s not bad under full load and I’ve added DODO deadn pad to the boot floor but coming off power and pick up after gear changing is too noisy. Much more than before I changed. I like the positive shifting but I think that will anyway be better with a new OE mount vs original OE mount.
I’ll report back if it makes no difference ?.
I’ve at least acquired to Stop brackets from 9Apart.?
Thanks Martin. I think almost all these boxes nowadays have a bit of noise like you describe. Can't say I noticed the mount changing that much but maybe it did? I'm on my 2nd gearbox using the semi solid mount. I think its pinion bearing noise but I find having the fans on 3 or 4 speed removes it completely :p , and other annoying sounds lol.
I can hear similar noise like you describe at low revs and part throttle, it goes away over about 1.5k revs or employing the throttle in any meaningful way.
All successfully swapped out yesterday, although getting the lower damper bolt back into the aluminum arm has been fun (not).
Just did a 25 mile trip in the car and its incredible how sweet it is for me now. The noises have gone, the car when cold isn't noisy, gearbox and diff not heard and because I'd put a few pieces of DODO Deadn on the boot floor surface the road noise is also reduced from the rear.
Anyone want a Rohler mount, slight use.
Was £238 now reduced to £215 at D911 in their sale.
£150 to anyone here including post.
