Torsion bar delete .
- Thread starter pauly
John Sims
PCGB Admin
I would be interested in any details anyone can come up with.
John, a cheaper upgrade is to fit much better bushes all around on the rear, the difference is worth it.
sawood12
The Kokeln solution is a complete custom built rear axel with swing arms. It is very expensive so you'd need to be very keen to go that route.
http://www.kokeln.com/rear_suspension_kit.php
Neil Haughey
ORIGINAL: sawood12
The chap I refer to with the S2 race car reckoned he could adjust the rear ride height with TB's installed in around 20mins. He drilled holes in the side of his sills to enable access to the ends of the axel.
I am sure one of the PCGB race cars I looked at last year had this done, surprised me because I thought the rules asked for standard panels except for front wings and bonnet. Tempted to do the same on my S2 rennsport projekt.
Just found loads of pics on here of a different PCGB race car with the same mod
http://www.944racer.com/oulton_park/photos/
Big Dave
They do a fine job..
The weight distribution is in the correct area, ie, VERY low...
If you have a 944 + its a track biased car then do the hole cut thing in the side cills, to lower it...
All the UK Race Porsche 944,s etc that i know of , run with the bars in. They have to for the regs...
Its not that hard a job to re-index, its just been "talked" up a lot , that its "supposed" to be hard. Yes its a long winded job.. + it helps to have the car on a 2 post ramp, But its not hard to do...
The chap that had the Kokeln rear delete kit.[In his 968]. Had a lot of "fun" getting it to work correctly. In fact it was quite a handfull on track . Im not too sure about the getting the power down bit. I know that it "wagged" its tail an awfull lot under heavy braking...[8|][8|] Oh it cost FORTUNES.. In my eyes not worth the metal....
Your far better off spending the money on some driver training if you want to go quicker....[ Thats not to say you arent a good driver now.] But ive yet to meet any race driver that thinks hes fast enough...[
John Sims
PCGB Admin
ORIGINAL: Big Dave UK
.....Oh it cost FORTUNES..
Seemingly IRO $2,400 [
I've not been that taken with Kokeln products in the past any way. They seem to almost but not quite fit the way you would want nine times out of ten. £2K+ (+coil overs, bushes and set up) is a lot to spend on something that isn't exactly right.
John Sims
PCGB Admin
http://www.elephantracing.com/suspension/bushings/944bushings.htm
Comments?
Big Dave
Yes i have those fitted aswell. Great upgrade..
But like Pat, i fitted a lot of solid bushings at the same time, so cant realy comment on the E racing ones on there own...
Re torsion bar stiffness.
The 968 ones are the thickest , ie stiffest you can , unless you go aftermarket...[ PS i do have a pair of 68 ones "spare".]....[
Peter Empson
ORIGINAL: John Sims
This was my other consideration:-
Comments?
Another vote for these as well, also used in conjuction with other stiffer bushes. You can have good fun fitting them as well, US customs take a great deal of interest in them if they are in your bag[
The 968 ones are the thickest , ie stiffest you can , unless you go aftermarket...[ PS i do have a pair of 68 ones "spare".]....[][
I thought all the late ones are the same dia, CS M030 had the additional springs on the rear shocks to stiffen them up ?.
It is fun to fit them, or more correctly to remove the originals which are pretty much Vulcanised on rather than inserted. I'd recommend doing as I did; remove the rear beam, strip and remove the bushes, paint the parts, reassemble with new bushes and reindexed torsions, spot that the mounting brakets are failing and buy news ones, curse that they cost about 250 notes + vat when you order them (and are Porsche only) and then reassemble. I also replaced the fuel and brake lines with genuine at the time. I'd estimate my rear axle refurb cost in excess of a Grand to do all the "while you're in there" stuff...
Peter Empson
ORIGINAL: barks944
Just had a look at your website Peter. Nice car, how do you find the innovate kit. Ive just picked up a g3 gauge and wideband controller.I hope to use it to tune my dads tr4 and help me develop my MAF converter. This leads me to my second question, how much of a difference did you get from the scivision kit?
Thanks Tom. I didn't get the Innovate installed for long before it went into the bodyshop so hadn't sorted out some teething troubles (this was with the logging side and not the Wideband). It's definately an impressive bit of kit if a little over complicated.
The Scivision made no improvement in power when fitted although rolling road remapping did find some gains but how much where attributable to the maf is debatable. Purely look at the dyno plots tells you very little about it though, the throttle response and resulting improvement in driveability is a major plus and worth the price for this alone. If I was doing it again I think I'd go with the Vitesse system as it has more potential, but if you're not going mad with mods then it's fine.
Last thing to consider is that (for a Turbo at least) you can't use the OE location as it's not far enough from the header and hence too hot. I can't see why that would be different for an NA car but Peter might be able to tell you different.
