Tailgate Latch Seals
scam75
Well-known member
Morning All
So both my seals have seen better days and are letting in water, replaced both about 15 years ago when they were about £15 each from OPC. I knew they had gone up but £65 for the left and £63 for the right (and that's including discount!) is not funny for 2 bits of foamy rubbery stuff!
Anybody have any suggestions or happen to have a lovely brand new set squirrelled away they would sell?
Thanks in advance
Stuart
Fook it, I bit the bullet and ordered them, they had a couple available in the UK, get them Saturday. I suppose £128 is better than water pissing into the boot all winter.
On a side note, does anyone know if you tuck the 2 collars under or over the tailgate seal? I've had them under all these years.........
Stuart
Still leaking after heavy rain at the weekend! I think there may be small to very small ingress from the latches, hard to tell, however I'm now looking at the light clusters which were sealed with black sealant out a gun when they were last out. OPC wanting £68 for 10m of butyl seal but have seen and ordered this instead for £22 delivered:
I imagine I'll have lots of fun not only removing the clusters but also then removing all the black stuff............. ?
One day the boot will be dry!
Stuart
Well it would seem I'm in line for boot flooding twonk of the year. It appears that after I unclogged the catch tray under the lock latch (which was causing a lot of unwanted water ingress), I have inexplicably re-fitted it upside down with the drain hole at the high side ? . Which would explain why water has overflowed, filled my light cluster and drowned my boot. Oops.
Now oriented correctly and boot carpet out again to dry!
It would also seem I did not need £128 worth of new latch seals. I do however need the light sealer I've ordered as the OS light has a small leak that causes no carpet flooding as it runs down harmlessly into the rear quarter well and out the drain hole. I suppose that can also now be fixed!
Glad I noticed before re-sealing the light and still having water cascading in..................?
An expensive and time consuming and head scratching affair all caused by gross incompetence!
Stuart
and the award for boot flooding twonk of the year goes to....... :ROFLMAO::ROFLMAO::ROFLMAO:
Love that, and so glad you spotted it before making everything very permanent
Yes you and me both Paul! :ROFLMAO:
I can confirm that after a few days up here where Noah would have struggled to keep things afloat, that my carpet is still lovely and dry!
