Eric_Oz_S2
Resurrecting an old thread, but I thought I'd chime in. I'm currently developing my own S2 supercharger install using a Rotrex SC and keeping the AFM. Also using the 951 intercooler and turbo injectors (as per Peter's).
Tuning will be done using the Ostrich 2.0 emulator and tunerpro. This way I can adjust the timing and fuel to suit and potentially also run dual maps (using the coding plug). As boost is progressive with RPM, I can adjust timing purely by rpm as the two are always related (unlike a turbo that uses a wastegate). Boost will be somewhere around 5-7 psi - the actual value to be determined through trial of various pulley size and dyno results (need to keep rwhp to 246 to keep in planned class for next year).
The install is still underway, but here are a couple of progress pics.
Oil cooler has been installed in the left hand side using the existing support that mirrors the support for the engine cooler on the RHS. Simple brackets fabricated using 40x3mm galvanised steel flat bar and utilising the existing holes in the body. The cooler is a very tight fit but almost looks like it was made to go there. Cooling ducts in the front bumper cover line up nicely with the cooler. Some rubber grommets help isolate the cooler from vibration and give it some give between the radiator support frame and bracket. There is about 2mm clearance from the modified horn location to the cooler.
Also mocked up the basic hose system for the intake. It is amazing how much you can outlay on the various hoses, couplers and clamps. It would have been cheaper I think fabricating up most of this as hard lines, but at least this way I can easily adjust the setout. There are still a few pieces to install in this system.
The intake area is really tight. I am having to use a series of 45 degree bend and a 90 degree bend to get the pipework between the AFM and behind the front guard/fender. The cone filter will sit in the wheel well in front of the inner wheel liner and behind the front bumper cover. The hoses shown are not necessarily the right size, but show how it will fit together. I couldn't find anywhere to put the rotrex oil reservoir except in this busy little corner. It just squeezes in and is supported partly off the AFM. It may require a single hole drilled in the body for the lower bracket support.
