sunroof problem
- Thread starter Alpine
To retract the arms (releasing the panel) the ignition needs to be at position 1. To raise & lower the roof you need to have the ignition at 2 (lights on on in the dash). Activating the central locking should make the roof lock too if the panel has been released.
Lots of possible problems with the sunroof mechanism, both mechanical & electrical. I'd have a look on Clarkes Garage.
Diver944
Any new owner to 944's should bookmark www.clarks-garage.com asap, it is a brilliant resource for the 944 [
Diver944
ORIGINAL: dodgydal
On the log book it states that it is a cabrio.
It's a common error by the DVLA [8|]
My own coupe is listed as a Cabrio and many people apparently own a Turbo Lux (no such thing) while a few S2 owners are listed as an S
or a lot of us are driving cut n shuts [
Diver944
Bonzo
I'm gonna print out the (daunting..?!) Clarkes Guide and go through everything when I get a day off.
Also, my arms only ever move with the ignition fully on. Pretty sure they should only retract etc in position one.
Bonzo
http://www.porscheclubgbforum.com/fb.asp?m=433692
robwright
Hope you had a good holiday!
If you want to drop round we could have a good look at it - maybe go and see the S2 rount the corner, see how it should work.
Mike
