Suffolk944
Moderator
Beckers are great in both terms of quality and appearance if you can find one. I have a Grand Prix and its fab !
Erm ... Nakamichi may well produce units which provide excellent quality source signal, but this is only good if the rest of your system is up to the same quality. Any sound system is only as good as it's weakest link, and the weakest link in most car radios is their amplifier. If you are after better sound quality from your stereo then buy a small amplifier and put that in the system; it will make far more difference (and cost far, far less) than a fancy-dancy head unit. Next step would be to spend some pennies on some capacitors to build some filters for the speakers to ensure they are only fed frequencies they can handle. Oh, and put some sound-proofing in the doors, and reinforce the speaker mounts to provide an enclosed baffle behind. Next step would probably be some better speakers. Then, and only then, will you start to really experience the benefits of a very high-quality signal such as that from a Nakamichi head unit - which would be your next purchase after the speakers.ORIGINAL: colin944
Seriously Andy if you want the best sound quality then check this site out http://www.nakamichi.com/home.html you will not get better quality sound this side of a linn system.
ORIGINAL: colin944
ORIGINAL: zcacogp
Of course, if you are looking for other features (Bluetooth, iPod integration, DAB radio and so on) or aesthetic pleasingness then you may choose differently.
No, it's totally different. The answer isn't "buy an S2"! [ORIGINAL: Hairyarse
Fair point Oli and that I understand. I guess getting the best out of your ICE can be similar for the search for more boost! []
Thanks, Big Boy! [ORIGINAL: Hairyarse
Thought I'd line that one up for you Oli []
ORIGINAL: colin944
Trouble with more modern factory stuff is that it works on can bus and therefore wont work in our old-fashioned cars.
This is a list of functionality requirements rather than quality, and hence all you need to do is replace the existing head unit with something that does all these things.ORIGINAL: Hairyarse
Whilst I don't want any crap in my car as I appreciated decent sound, I'm not looking for a full-on ICE install, as my head unit has no MP3 compatibility for my iPod this is what I need - plus if I'm buying something new it seemed to make sense to consider something with blue-tooth too so I can make hands-free calls through it too
