IanHighfield
I had to make a 'temporary' repair to my steering column unit over the weekend.
Symptom - dipped beam would go off and return to side lights only - fiddle with wiring and it came back on.
Removed steering wheel and column unit and found the plug had a loose wire, and the switch unit had a loose connector.
Fixed as best I could and a cable tie has drawn the plug in to the socket well enough for it to work again.
So, I am on the look out for a three stalk unit including OBC (or is this completely separate ?) to use as a replacement. Used is fine if known to be working well.
Ian
Ian
