Service on 2014 Turbo S
pboldmonts
Bit of a rant I suppose!
The service on my car, which has done !5k miles is coming in at around £2000!
Standard price for the major service, £400+ for new spark plugs (really), brake fluid change and MOT. Then, I get a call saying "the anti roll bar link is leaking, it has to be replaced as it will not pass the MOT. £750 for the parts and an hour of labour.
I'm starting to question the quality of a £160k car that needs a new anti roll bar link at 15K miles.
Not what I would expect from Porsche - time for a rethink!
Rant totally justified!!
My 2014 Turbo S had its scheduled service on 3rd February at 12,488 miles. Pretty much the same cost without the roll bar. (I took out the extended warranty just in case)
Plugs were £93.12 and fitting was outside the so called "fixed menu" pricing so labour quoted at £145.00 per hour plus our 5% GST (I live in Jersey). Our aircraft technicians in Bournemouth charge £55.00 per hour unless the job is a specialist one.
My total bill was £1,221 but I had a "discount" on the menu pricing as I booked early!
btw how are your tyres, I have just had to order my second set. The Pirelli's are rubbish but it seems that due to a cosy deal only Pirelli produce the correct size rears unless you go for Michelin Club which are really for track use and their life is even shorter. 6000 mile for a road tyre is unacceptable. My Bridgestones lasted over 18,000 with the same pattern of use on my 997 Turbo
The good news is that the tyres are all OK. Fronts have 4-5mm and the rears are nearly new so fine. The thing I find incredible is the cost of the parts to replace a roll bar link. £750!!! Must be made of gold!!
BTW - the rear tyres were changed with about 3mm of tread but had a slow puncture in one so had to change both. Must try driving a lot faster!!!
Totally with you on this one Peter.
I have the same model and over the last year and a half I have had a faulty lambda sensor, a faulty gearbox sensor and 2 leaky seals/gaskets where the gearbox connects to the driveshaft.
I have also had rust appearing on my front wheelarches.
It has really put me off the brand, the build quality seems shocking. I am lucky I had warranty but it is really not worth the hassle, such an expensive car is a toy that is meant to bring you pleasure not constant aggravation.
Guess they don’t make them as well as they used to
pboldmonts said:
.....The thing I find incredible is the cost of the parts to replace a roll bar link. £750!!! Must be made of gold!!
Peter,
My thinking is that you have Porsche Dynamic Chassis Control with actively adjustable hydraulic links in the anti-roll bar, one of which is leaking? At £750, almost as expensive as gold..!
An extended warranty claim on the link, perhaps? [;)]
On the question of servicing costs, £2K over a period of 2 years, i.e. less than 20 quid a week, seems a bit of bargain to me for running a highest performance supercar of this type. [:)]
Compare the alternatives, I ran a new Ferrari for 2 years. This seemed to cost me a couple grand every 6 months or so for one reason or another - servicing was annual too and definitely not cheap. Also, it is not uncommon for McLaren owners to get £6k+ bills for their annual services.
So I think we need to be grateful that Porsche engineering is so resilient! [s5]
Regards,
Clive
