peanut
nice bit of fabrication Rob ...hows you welding technique on thin panels [
Not trying to teach my GM to suck eggs or anything but if its any help to anyone reading this and contemplating welding body panels I have found the best technique for limiting panel distortion due to heat buildup is to do a series of small isolated spot welds about 2" apart along the join to tack the panels together then let the panel cool . I usually use a towel drenched in cold water to constantly keep the panels cool as I go .
then I fill in the gaps one at a time cooling the panel as I go with the towel and always welding on a different part of the panel from the previous weld.
Its rarely done these days but in the past panel beaters would frequently braze panels together which gives an excellent joint on non structural panels and even use lead to wipe joints and form shapes like the side lights on Mkll Jags . Both of these techiques reduced the amount of filla needed and limited subsequent oxidation .
