Satnav issus
davidbuchanan
Thoughts welcome:
1. Porsche satnav crashes and reloads. Too often.
2. Apple Maps stops receiving battery information.
Yr23 Taycan cross turismo.
Software version 3882
OPC advised a factory reset, with no luck. car due a service in Sept so it can be looked at then.
In the meantime….?
Same issues, seems like I’ve had numerous OTA map updates but Porsche navigation crashes constantly and then resets without retaining journey.
Apple Maps issues are common, think I’ve had regular battery information alerts for months. Haven’t tried a PCM reset using the top right corner trick, should try that really.
Hello. At least I am not alone. I have literally just had Porsche on to book the car in for service and I mentioned the sat nav issue. Seems there is a fix in the pipeline, they say hopefully being run out in a few months time. They asked if I fancied doing a quick check/fix over the phone, but I was not in a position to do that. I'll manage until the car goes in for its service.
I know Car play is good, but the Porsche sat nav is quite good, or just as good.
