S2 Engine Problem... Sounds serious, anyone know of an engine for sale?
- Thread starter tref
chrismanchr
there was a whole working s2 engine on ebay a few weeks ago ,it was 500quid ,I know a place in coppul near wigan has a red s2 theyre breaking at the moment
as ive considered buying there gearbox ,on the advert it says you can come and test the gearbox as the engines ok ,that means they'll be selling the engine soon
the gearbox is on ebay at the moment its on at 292quid
Just collected another engine from Jon... a few bits to swap over, and then I can take a look at my old engine at my leisure (which probably means it will join the other two engine I have waiting for me to pull the head off and see what is wrong with them... but this one is more interesting!)... Guess what I'll be doing the weekend... that's right, MOTing the cab![&:]
chrismanchr
chrismanchr
ORIGINAL: edh
So Tref - having seen your post on the mileage thread......
What was the final diagnosis?
How do you make the font on this really really small? distributor cap[
924nutter
ORIGINAL: 924nutter
That's 8 knocks per second using the you tube time base so I if that is a single piston hitting a bent valve the idle speed would be 480 rpm, (8x60) It is regular but as the number of cylinders involved goes up the idle speed would have to go down. e.g. 2 cylinders give two knocks per rev instead of one so to get the same 8 herz your engine would only just be above the 200 rpm rotational speed threshold of the dme, so that rules out all four as well because it just wouldn't be ble to run, but in any case I would expect an engine firng on three to make better than 650 rpm. If the engine is idling normaly and it cetainly doesn't appear to be rocking about from side to side, so it's sounding like it's something that operates at camshaft speed. Balance shafts are out because the whizz round at twice engine speed.
You haven't got a bent valve because you say it has acceptable compression and presumably good oil pressure. Is it possible that you have a sticking valve which isn't fully closing until the piston gives it a whack? A sticking valve will cause a bit of a misfire, and if it is the exhaust valve you would still show good compression figures because once the piston had pushed it shut it remains that way until after the compression stroke.Have you checked that the securing screw for the rotor arm has not worked it's way out and is hitting something at one particular point on its way round, or is it not the same as the eight valve?
Has one of the many tappets failed to pump itself up due to perished seals or blocked oilway
Has the timing chain jumped a tooth? There again again if it had you would have at least four bent valves and poor compression.
Not definitive answers Trefor but more a case of what it isn't, which may be of some help.
edh
For clarification the volvo cap was on the s2 - they are supposed to be compatible. (I tried 3 and they all made the same noise)
Seriously though that is a bit gutting for you tref - I guess you have a fresher engine now though. Mine is on 234k and only used for trackdays now. It won't do many miles, but they will be tough on the engine. I am intrigued to see how long it will last
It is like ball joints... I will try a reconditioned one - if it lasts for 30k miles, most people will be happy, for me, I can't afford to be changing the wishbones every year, so it will probably be worth my while paying £500 for a pair of genuine ones...
Trouble is, if you are prepared to go out on a limb and try stuff, every now and again you are going to fall down.
edh
At the time i spoke to PH sportscars about it - they had never seen the problem, but now there's 3 of us who have had it..
chrismanchr
