Rusty wing
- Thread starter J4CKO
ORIGINAL: 944 man
Other will advise you better than I can, but its best to do a lot of reading about taking wings off before trying. There are a number of concealed bolts and even when you have them all, the bastard things will still be stuck on.
Yes, I dont fancy removing it, though I have removed them before I have never had to re-use them but not sure how I will let new metal in to that back edge with it on the car.
Diver944
From memory there are two bolts under the under seal where the wing meets the front door. Looking at picture 4 I think one of them has totally rusted away inside the recess to the right. Even with all the bolts removed you have to give the wing a damn good tug as it is almost 'glued' to the body with sealant
Got the wing off, depsite the dire warnings, wasnt that bad but now need a source of new fasteners, any suggestions ?
As I suspected, the shell hasnt rusted, its just the rear part of the wing as this is what was behind the hole
The offending bit,,
And from underneath,
And another form the back, riveting stuff, im sure you will agree.
One of my front wings needs doing and it's worse than that... completely corroded at the bottom, at least yours you can still see the basic shape to work to.
Rob, not sure how I would tackle it without the shape, its basically instact but wek, just let a small piece in but decided after faffing all night it is time to go in and leave it as getting slap dash, made another piece, just building the strength back into the panel, doesnt have to be pretty on the inside, just strong and then covered in rust proofing.
Just asked OPC Cambridge to track down a driver side sill for me... also noticed wheel arch rust on the rear quarter (the other side from the one I repaired). Think I may have to drop the fuel tank for safety before welding around there...
Another saga begins!
