Porsche warranty extension
With the exception of the CarPlay upgrade, which would technically void the PCM from the warranty as the seal on the case had to be broken, the other elements are not related to the warranty and therefore do not affect it. The brake system is covered but not discs or calipers. On suspension the springs are covered but not dampers etc. Generally anything that is subject to wear (apart from the engine) is excluded.
Just a note on this, the warranty wording doesn't state that brake discs or calipers aren't covered or are excluded, that's not true. Shock absorbers also, it's not true to say they aren't covered or that they are excluded.
The most recent wording (and follows the lines of the previous versions if my memory serves correctly) states:
"The Policy does not cover any system or component on the Vehicle, which is defective, fails or requires replacement where such defect, failure or requirement is due to wear and tear."
then goes on to say:
"Below is a non-exhaustive list of items commonly subject to wear and tear, which if fail due to wear and tear will not be covered by Your Policy"
And it lists a bunch of components.
So the key here is that wear and tear isn't covered, and some components are more commonly subject to wear and tear, but it doesn't exclude those components from cover. If they fail due to wear and tear it won’t be covered.
Some real world experience: I have had one of the more obvious components subject to wear and team (a brake disc) replaced under the Porsche warranty. Without going into too much detail: the construction of the brake disc failed, and Porsche replaced it under warranty.
Hope this clarifies, and as an insurance underwriter of 20+ yrs I can always happily give a view on insurance products.
What is the definition of an authorized Porsche service center for extended warranty purposes; does it include PPN Indys? If you ask the latter they will say it does. Somewhat unsurprisingly, an OPC will tell you it has to be only them but they want the money for servicing and generally have limited scruples. It seems to be prudent to get confirmation in writing from the underwriters themselves or PCGB here. As the costs of OPC servicing get more and more usurious, the only thing keeping many of us servicing there is warranty upkeep. If a decent Indy will do the same service for 40% of the price with no warranty impact it becomes virtually a no-brainer.
I read recently that many OPCs will be installing mocktail juice bar with trained baristas. This can only mean the cost of an oil change climbing further!
Porsche UK based Customer Relations Hub is available to support and guide customers by post, telephone or email.
Phone:
03457 911 911
Email:
contact@porsche.co.uk
Post:
Porsche Customer Relations Hub
Porsche Cars Great Britain Limited
Bath Road
Calcot
Reading
RG31 7SE
Suggest you make contact requesting a list of independent Authorised Porsche Service Centres. I suspect it will not be a long one, however we would all be interested to hear the response. 😉
Regards,
Clive
Indies who are PPN's can do warranty work. What they cannot do is sell a warranty.
Obvioulsy in the context of a defective component, then it would be covered but that is going to be very hard to prove once the part has been used for a period of time. I know of someone who had a deformed wheel on a GT4 but Porsche (or the OPC - I cannot remember the exact situation) would not honor the warranty on this. The wheel was not damaged by an impact but 'failed'.
The basics, as far as warranties are concerned, is that if the item is subject to wear, it won't be covered unless you can prove otherwise. It is however also a fact that different OPC's will have different opinions as to what is under warranty or what impedes it. You must stand your ground or seek opinions. Not just accept the view of a dealer who, ultimatley, cares little.
I also think it depends on the relationship you have with your OPC as to whether they push for your warranty claim.
Dan.
