I have a Panamera 4S G1 (970) with a strange problem. I recently disconnected the battery and upon reconnecting it the time did not sync to the GPS almanac however the nav works fine with good satellite reception of between 6 and 10. I put another GPS antenna in but it was exactly the same. The date and time started counting from 01/01/2007 and 0000hrs. the time in the settings menu is just dashes and the chrono syncs to the incorrect time from the PCM. I have also lost the time interval for the service indicator which now only shows distance. I have scanned it with a PIWIS 2 and there are no obvious faults to do with the GPS/PCM. All other functions work fine. I am at a loss with this fault and am wondering if anyone else has come across this.
Well an update on this for everyone interested. I sent the unit to a repair facility who tested it and confirmed it was a GPS hardware fault, but unfortunately they are unable to repair it. I stuck my neck out and got a used one from the online bay we all use. Replaced the unit using PIWIS 2 to read/write the data from/to the replacement. Did a vehicle handover on the replacement PCM to erase all data from it.
Hmm not much in the way of a time signal to be seen. Left it on for 10 mins but no change, so decided to disconnect the car from the power supply and move it to a more open space. 3 minutes layer bingo all maps.date and time all synced up fine. So definitely a hardware fault.
The only issue I now have is that the replacement unit goes not have AUX BT enabled so am unable to connect my phone, but I do have an I pod option which I didn't have before.
More research required
