Neil Haughey
OK guys, as I am in the process of stripping out the inside of my car I thought I would start compiling a list of how much stuff weighs. I will edit this message from time to time as I add more bits to the list [Updated 12/3/12];
Carpet:
1) Rear load deck carpet 5.5 Kg
2) Rear floor carpet, in 90 S2 goes over transmission tunnel and finishes under front of seat 2.5Kg ish
3) Rear quarter carpet goes over wheel arch by rear seat and covers rear quarter in the boot, each side roughly 1Kg
4) Footwell carpet goes from front of seat and covers everthing else in the front apart from outside of each dash side, roughly 1 kg each
5) Some odds and ends of carpet that weight practically nothing so I haven't weighed them, they include 2 little pieces that cover the vertical front face of each seat, roughly 1 foot x 1 foot and 2 small pieces for each footwell under the dash on the outside i.e. on drivers side covers the ABS ECU on passenger side is the bonnet release.
Total is roughly 12Kg, much less then I expected.
Front Seats:
1) A leather sports seat from originally an 86 turbo (or may have been same age 911) = 27 Kg each
2) A pinstripe cloth seat from originally my 90 S2 = 24 Kg each
Total for sports front seats 54 Kg, much more then I expected and also tricky to balance on scales, Steph is not happy that I have scuffed her scales so some new scales and flowers will be required.
Rear Seats:
1) Seat base 90 pinstripe S2 and 86 turbo leather (vinyl really) = 3.4 Kg
2) Seat back including roller blind, 90 S2 and 86 turbo = 11 Kg
Headlining:
Includes roof rail rubber pads, front panel, rear panel and sun visors = 3.8 Kg
Spare wheel well stuff:
1) Tool roll, compressor and warning triangle = 3.2 Kg
2) Jack = 2.2 Kg
3) Spare wheel = 13.4 Kg
Sound Deadening;
Rather then break this down into individual pieces I will try and lump car sections together.
1) Rear of car from back of floor backwards but not including roof, = 7.5 Kg
2) Transmission tunnel excluding one small piece under heater which would have been a royal PITA to remove = 3.2 Kg
3) Passenger bulkhead = 3 Kg
4) Drivers side bulkhead = 3 Kg
5) Floor pads under your feet when in front seat = a tad over 2 kg each circa 4.5 Kg a pair
Total is roughly 22 Kg as there are a couple of little bits I couldn't get out easily so have left in for now. Note that this does not include the rock hard sound deadening pads that cover the trans tunnel and floor, and are body coloured. They seem to be a nightmare to get off so I have left them for now. Also note that headlining stuff I have listed separately. Also note 2, the transmission tunnel is a bit of a pain as much of it goes hard and brittle from age and heat and thus has a habit of coming apart in hundreds of pieces. The floor and bulkhead though just have to be eased out and come away leaving no residue at all on the panels, its just a tad uncomfortable being under the dash for so long.
Now for the big stuff that I know many of you have been waiting for;
Hatch (without struts or wiper) = 25.2 Kg
Sunroof panel (complete) = 9.6 Kg
Steel wing (complete) = 6.2 Kg
Front bumper PU complete with lights, bumper cross member and supports = 17.2 Kg
Front airdam that fits under the PU = 2.6 Kg in other words the front bumper total is roughly 20 Kg
Badge panel = 2.6 Kg
Bonnet complete but hinges still on car = 17.2 Kg
Stripped bare dash panel = 7.6 Kg + about 2 Kg for all the other bits of dash trim gives a total near to 10 Kg for the dash
Door (complete but with stowage bin armrest removed) = 27.4 Kg
Door stripped bare = 16.4 Kg
Electric window complete assembly = 2.4 Kg
Rear Bumper (complete) = 7.2 Kg
Wiring loom (complete except doors and engine loom) = 22.4 Kg
Headlight (complete but without painted cover) = 2.2Kg per side
Headlight motor = 2.2Kg
Headlight bar and bolts etc = roughly a kilo or so.
I am still a bit surprised at how heavy the doors are, especially considering that these are not normally mentioned and the Bonnet and wings are not really that heavy.
Gearbox with LSD = 55.6 Kg
Dansk SS replacement exhaust = 11.6 Kg,
OEM SS exhaust = 15Kg,
7"x16 Cup 1 wheel with Contisportcontact 205 N tyre = 16.6 Kg
7"x16 Cup 1 wheel with Hankook RS2 225 wide tyre = 18.4 Kg
Surprising just how much difference 2 different brands of tyre makes.
Carpet:
Front Seats:
Rear Seats:
Headlining:
2) Jack = 2.2 Kg
Sound Deadening;
