My Attempt at a metal wide body build
Day 4 had some professionals the course learning the tricks of the trade
polishing day
first 1500 wet sand
then 2000 wet sand
pizza break
then 3000 on a DA sander
3000 on a rotary
9000 polish rotary
then final buff with the orbital
results speak for themselves
anyone wanting a car painted or the training I highly recommend Gavin at the paint shop
Tested it out today 2 coats of epoxy
had an issue with the dryer it uses too much air so got a little orange peel on the bonnet but wings came out a treat
Gravity Gun
Ah yes I see the Gravity gun in the first pic now. When I left school I did a few months in a paint shop, before I started an engineering apprenticeship. Learned how to use a velocity cup to mix the paint, but always preferred using a pressure pot. A Gravity gun full of paint got a bit heavy for a skinny 16 year old after 7 or 8 hours :).
I think stripping the paint is by far the worst job but we’re all done and in the booth ready for the first 2 coats of expoxyIMG_2789.png
2 coats of Novol Classic car Epoxy applied
just another 8 coats to do :confused:
now I start on the body work the primer has A Sheen so it shows all the defects so I can see the main areas without guide coat
its only 50mm wider than standard but the rear arches look so much bigger now they have paint on :)
