My Attempt at a metal wide body build
The original roof skins are spot welded on, fairly simple using a spot weld drill bit to remove the skin, and then weld in the drill holes. If I was filling the hole in the roof with metal I'd tack it in place, and then gas braze the rest
I didn’t really want to remove the screen and I wanted to keep the sunroof opening structure
And my welding skills are limited :( so brazing is not a option agree it’s the way to go if you know what your doing
started the spray booth build
designed so it’s a 4mx4m for painting panels but then extends with a little work to 6.5x4m so will take the full car
cross Flow with IR baking heaters and plenty of lighting
Blimey is this just temporary for one spray job? Wouldn't it be cheaper to get a body shop to paint it?
it was being thrown away only a couple of years old so cost me nothing
i think I’m going to keep it as it doesn’t really use any room.
best price I had was £18k for all bodywork and full Novol bare metal respray but I think DIY will be £3-4K a lot of work and I like doing it myself
£18k!!!! blimey, was it gold plated paint?
I had a very good full body respray on my 996 for around £3.5k, admittedly I did most of the dismantling of the body and removed glass and seals.
Didn't realise the spray booth cost you next to nothing so that is something (y)
I admire your enthusiasm, I will have a go at most mechanical things, but painting is something I've never had the patience of skill for 🫣
18K included sills and wide body work - £3.5K gets you a respray but not back to bare metal - my thoughts were its only paint if its not right just sand it off and do it again 😅 and its quite rewarding
now engine building that I didn't fancy I had Simon Peckham do mine 🙂
I’m the opposite - I’d rather build the engine than paint the car, we should team up :ROFLMAO:
A guy I know used to be a decent painter in a Ford body shop. Saw him a while back and he told me he had painted his Escort RS2000 in his double garage. I think he had sealed it up with polythene sheet and had a fairly basic extraction system rigged up.
the panting isn't that hard as long as the air is dry and the environment is clean -its the prep that takes the time and skill -well at least that's what I'm hoping !!
The booth came of of my works I designed it 4 years ago cost £180K but we now have robotic spray machines so it was scrap and know one wanted to buy it so I had it will be air tight when complete so I'm hoping for a good finish -time will tell
Yes muck the prep up and all sorts of nasties can surface. Will you be aiming for modern day orange peel or a glass like finish.
Day one of the Novol Classic car painting course:)
only 3off us on the course so it’s one to one virtually
from bare metal -epoxy-filler-polyester primer-epoxy isolator-base-clear then one day wet sanding and machine polishing
it’s going to be a full on week.
That is excellent, is this with Gavin at the Paintshop? I've bookmarked that in case I ever feel inclined to do the same one day!
Do let us know how the course goes!
the finish they on some of the cars in the shop is amazing View attachment 3623
Have you decided on the colour yet?
I love this colour it is Nile green I think
underberg seems similar but not metallic
its the look I’m going for
I did 2 days of the course it was excellent
but unfortunate circumstances meant I couldn’t continue but Gavin has said I can go back and complete on the next course
Day 3 of the Novol classic car painting course
lots of sanding then 2 coats of base and 2 coats of scratch resistant clear
came out really nice tomorrow we polish
Just to show how good the finish is with this paint -this is the reflection without any polishing
the finish is achieved by painting the base in 2k
so base and clear mixed - I think it’s called single stage
but then shoot 2 coats of high solid clear over the top.
this gives a lovely deep gloss finish
the full Novol process is
2 coats of epoxy
2 coats of polyester
2 coats of epoxy
2 coats of 2K base/ clear
2 coats of clear
and lots of sanding
highly recommended the training course if anyone wants to have a go
