Motorsound airbox cover
- Thread starter harry
I had one on a previous RS, but have no clue of the actual part number fitted....I sold it to someone with a varioram C2, who never complained, so I assume it fitted?
There is a motorsound airbox part no 99311003056 which looks like the clips are in the right places to fit an RS.
I would be amazed if this did not fit, maybe try before purchase if unsure or agree a return?
You can definitely buy this item on it's own, without the fancy exhaust tips, last I recall, around £60-65, but with "Porsche tax", it could be anything now (not less!)
You do realise that the new box cover has a few holes drilled in the side and a plasti-chrome finish to the air intake.
There is no more power, just intake noise, which may be what you are looking for.
ORIGINAL: M030
You can fit the motorsound air filter cover on the RS, but you need to remove the chromed inlet and insert the cold air intake.
It will not give you any more outright power, however it can help maintain the power you have as it draws in cold air.
With the standard air box set up, if the engine bay is very warm and you draw in "hot" air, this can have the effect of less power, I assume down to the warmer air being less dense.
I was once told the standard ecu retards the ignition slightly (less power) if the intake air is too hot......I don't know how true that is?
So the crux of the cold air intake, is potentially more consistent power output over temperature ranges and people always asking "what's that?" when you lift the engine cover!
ORIGINAL: clubsport
So the crux of the cold air intake, is potentially more consistent power output over temperature ranges and people always asking "what's that?" when you lift the engine cover!![]()
It looks like a urinal [] Does it fit under M002 wing?
