pauljmcnulty
Running costs have become far more of a lottery over the last few years, as the cars have reached the point where both restoration and preventative maintenance become as important as regular servicing. This is why the advice to buy the best you can is so important, and to keep a chunk of money back as a reserve.
I'm discounting the DIY option here; you can obviously save a lot if you do the work yourself, but that's not really an accurate guide to costs for many of us. My Lux cost just over £1000 per year to tax, insure and maintain, and it's depreciation, over 5 years/30K miles. The S2 has cost more than £3000 per year over three years/20K miles, and still needs £000s spending on the bodywork. This is partly down to work I would have had to do on the Lux, as it also needed some TLC, but there are just so many age-related problems that can rear their head.
Things that will cost a lot are:
Bodywork, rust can cost £000s to put right if it's done properly and you need a lot of paintwork.
All the fuel and brake cables and lines are at the end of their life, calipers corrode and need refurbing, head gaskets are really needing changing, water pumps are often original and a belt service can also include seals, rollers etc. Clutches are on their last legs if original, and suspension is often shot. There are also numerous little things that can go wrong, and if it's going in to a specialist every time it all adds up.
A good buy will have at least some of the above in it's recent history, the more the better as there is little difference in price between the average, and the best.
It might all sound negative, but there's nothing worse than the people who buy a shiny 944 at a knock-down price, then find they can't afford to get it through the first MOT. Unless you are going to run it in to the ground and then scrap it, I'd treat it as a £10K car; if you don't spend the reserve you've not lost out, but at least you are prepared.
As I've said many times, there's no comparable car from the period that will rust less, or be more mechanically robust, let alone drive so well. What I guess you have to think very hard about now is if you actually want an old 944, when £10K buys an awful lot of newer car. Personally, although I am often tempted, I come back to the 944 every time. I am a bit of an obsessive though. [
