Well, noticed the level dropped a bit, so topped up, it barely moved but it was going somewhere, noticed (its an S2) that there was pink residue on the metal hose junction thingy on the fornt of the engine, the allooy corrodes and instead of white its pinkish which suggests thats the location. I changed the PAS belt today as it was slipping which was a faff as the tensioner was seized but it gave me chance to root around and have a look and there was wetness down there.
Anyway, took it for a spin to check the PAS belt was ok, got a little bit of steam, got home popped the bonnet and again, wetness, I prodded around and I moved the hose coupler, the black plastic one to the alloy houssing that goes back to the header tank and out pops a sprinkle of finest Porsche coolant.
So, pound to a penny have found the leak but why would it be coming from there, every time I move the pipe it will let some out, so,heat, pressure and engine movement must be letting some out, not much but dont want any coming out. the union between the plastic and the allow doesnt appear to have a gasket of any sort, should it ?
Anyone come across this before, I tried to tighten it but it doesnt look like it was loose.
I was concerned it might be headgasket or something but I am hoping this is a simple fix.
