Lightweight glass issue, looking for advice.
Mrmichaelsankey
My first post so be gentle. In 2021 I took delivery of a new 992 C4S. Roll into a few weeks ago and I opened the passenger door to put a bag in. I felt some resistance, then it opened. Upon closing the door, the door glass connected with the rear quarter light glass and cracked.
Car went to a local Porsche dealer, investigations were done. I had forwarded pictures of the glass straight after the incident along with a technical document #2308, lightweight glass cracking, yes it has lightweight glass.
Problem one…. The tech apparently said it wasn’t lightweight glass (this I had to correct with the service advisor) and secondly it was caused by external influence.
So as per the technical document, it is a warranty claim, but due to the external influence clause a warranty claim has been refused and they have drummed up £500 from Porsche GB, contributing £450 from the dealer and leaving a £400 hole for me to fill.
It’s not the cost, it’s the principle of it.
  • Porsche 911 Cracked Glass TSB 2308 (2).pdf
Did they say what the external influence was? It’s a known fault on the 992 that the door glass can catch the rear quarter resulting in breakage.
If you’re not happy then you could always take it to another OPC for a second opinion.
Dan.
If you don’t get any where with your OPC have a look at your windscreen cover on your car insurance. This usually covers all glass.
Thinking, stand your ground and ask them again to fully repair this at no further cost to you and remind Porsche that the onus is on them to repair this at no cost to you or prove this resulted from external influence including the full technical evidence that this resulted from external influence. Probably also worth highlighting the basic error by the initial technician in identifying the type of glass.
Also, check your insurances for legal cover and use that for advice from their legal service (note - quality of legal service varies tremendously between insurers).
Had similar experiences with several marques and all settled in full as 'goodwill gestures'
Hope this helps
Given my own experience with Porsche's customer service (although not with this particular issue), this does not surprise me at all. I would ask them to specify exactly what the external influence is - i.e. you were just opening and closing the door, it is utterly ridiculous that the glass should crack when subjected to a situation it was designed for.
So I’ve had a cracker with this today!
The dealer raised it with PGB using completely incorrect information. PGB have corrected this and are resubmitting for review.
The dealer now claims the glass is not out of alignment….either they have been into the door and done something or are just flat out being stupid. Proof in the pictures. Insanity!
Sounds like progress - expect you'll need to keep the pressure up and should be fixed at no further cost to you. Good luck.
Thanks! My Father, after 12yrs of having one, experienced an ICD trigger yesterday (real fancy pacemaker that can restart the heart), basically stopping a heart attack before it could happen. So my concern is with him now. OPC, OPC principal and PGB have been told “the next correspondence I receive will be the car is fixed and being returned to me, if this is not the case then I will drop everything in my solicitors lap for them to deal with going forward”
Dear Mr Sankey
Thank you for bearing with me.
I am delighted to confirm we have had a positive outcome today and we are able to replace the glass for you at no cost to yourself.
Following this news, I have placed the glass on order and should arrive on Wednesday delivery, it is most likely the earliest your Porsche will be ready is Thursday.
Can you please confirm that you are happy for us to proceed and that this time scale fits with your diary.
