Hi I’m thinking of doing some mods to my 991.2 turbo. Lichfield do a power upgrade to around 650bhp. They no longer do their own exhaust but have recommended Miltek plus sports cats. Need more sound in sport mode. Don’t want the drone though as like to drive it under the radar for a lot of the time. My concern is it being too noisy and regretting it and issues around my Porsche warranty when I renew. I figured I could just do the exhaust not the power upgrade to preserve the warranty on the turbo replacement cost which scares me. Any experience of this on here please?
Lichfield conversion
- Thread starter chris.brierley
If you use an external box to remap, that can be removed and is undetectable. I'm guessing Litchfield will do something different that is more permanent. If so, warranty gone.
Not sure on Porsche UK's warranty view on exhausts. In the US they allow such things but as its directly connected to the engine, plus the exhaust system has sensors in it, not sure that in the UK/EU its allowed. You need to research.
Note that all tuning like this just fools the sensors on the engine. It will provide more top end but its not a free ride. You will lose power somewhere. Usually low down.
I believe the .2 Turbo is solid. The .2 regular 'turbos' are a bit fragile unless they had the oil line mods.
650hp does not sound 'much' for the 3.8 Turbo. I thought they were promoting near that kind of power with the 3.0T. Not that I have really investigated this.
Thanks. The litchfield remap for the 991.2 as I understand it can’t be switched on and off. The safest course seems to be to leave the car alone.
Id say its probably a little more than that, new fuel maps, ignition advance, pushing rev limits etc and of course increase boost pressures across the rev range.
FVD do an OBD2 reflash and you can reset it back to factory before the car goes in for warranty work or servicing. I think they still offer PCGB discounts too.
Well yes, and also no. The sensors play a large part in controlling the engines limits. You can remap an engine but thats only reversable if you have the original maps. The common way to do it now is via an intermediate box which modifies the sensor data to get the cars ECU to behave differently.Id say its probably a little more than that, new fuel maps, ignition advance, pushing rev limits etc and of course increase boost pressures across the rev range.
As I said theres no free lunch. You cannot solely tune a car electronically. Turbo cars are easier because you can up the boost and dump more fuel. N/A engines are much harder. You perhaps refine flat spots but not much else. If you want to improve an engines efficiency then you have to improve both its volumetric efficiency and mechanical efficiency. A lot of GT3 engine improvements have been due to lubrication.
Now I don't know where this particular box lives on a 991 given the engine bay is inaccessible. But I have used boxes from these people and they definatley work. You just plug them in and unplug when you need to hide tthe tune.
991.2 Turbo has around 550 bhp. Are you really looking for more? Are you driving the car flat out everywhere and constantly wishing you had more grunt? If so certainly consider a power upgrade. However, for many it's all just bragging rights and as far as real-life performance is concerned, the money would be far better spent on a decent set of boots.Thanks. The litchfield remap for the 991.2 as I understand it can’t be switched on and off. The safest course seems to be to leave the car alone.
Regards,
Clive
My understanding is that everytime it's flashed it increments a counter, which Porsche would have a record of, if they had flashed it. At best it's a risk that it's not spotted by Porsche?FVD do an OBD2 reflash and you can reset it back to factory before the car goes in for warranty work or servicing. I think they still offer PCGB discounts too.
My understanding is that everytime it's flashed it increments a counter, and Porsche would have a record of, if they had flashed it. At best it's a risk that it's not spotted by Porsche?
True
Even if it were flashed back to standard, it would leave a signature on the ECU, as it would have been operating outside of OEM limits. In the event of an engine warranty claim, diagnostics would discover this.
The tuning box won't do this, as it intercepts ECU signals and 'tricks' it into providing more boost. The pain of this solution would be having to remove half a dozen sensor connections to take out the box each time it goes to the dealer.
Regarding Milltek, I personally would opt for something else. They're the bargain basement of the exhaust world.
Its doubtful the exhaust will be allowed with the warranty - especially with sports Cats
Sports Cats normally require to car to be tuned to make them work properly with car, so bear that in mind
If your an on road driver - Top end power matters little if its spikey (delivered over a narrow rev range)
Its the area under the curve (power through the rev range) specifically mid range so better torque and power in the mid range would give it a feel of more punch/responsiveness and better real world performance on the road.
As Clive mentioned, for road - top end on these things is more bragging rights than practical - unless you are tracking it
I am running a TechArt power kit which is fully integrated to the electronics - it comes in on sports and sports+, mainly mid range torque (up to 880nm) so punchier in the corners and on pick up when it's lit.
Suits me as I like to surf the torque
The pre-requisite is less than 30k miles and a thorough engine check/test before fitting and they require a BMC filter (albeit the engineers really like the Evenuri intake - official TechArt policy is BMC only)
In normal mode its allegedly stock but seems to give better mpg on a cruise
Allegedly it gives an extra 60hp - reality is it gives more torque and HP in the mid rev range. I doubt it does much at the top end
Reality is changing anything in the engine chain - air in, air intakes/filters/ engine, intercoolers to exhaust out probably gives a big out for Porsche on warranty claims
Hi for those of you who have had mods have you got mechanical breakdown insurance? I have been told there are other insurers (not Porsche) who do insure. I want to fit a Top Gear 200 cell cat back x pipe valved exhaust which seems good value. I am not going to do the remap.
thanks
thanks
Mate of mine was at a track day with his new Lotus Elise. There were some Lotus factory people there. He got in to conversation and asked them how best to spend his money to go faster. The reply was driving lessons.
Don't mean to be unkind, but look at the various offerings at the Porsche Experience. They are brilliant for all levels of driver, and wont invalidate your warranty.
Thanks. It’s not about speed. The cars fast enough. It’s just it’s relatively quiet as the 991 turbo doesn’t have a sports exhaust. You do get some noise in sports mode but it could do with more. I checked with Warrantywise and Motor Easy which indicated they were more flexible but they’re not. I will likely live with it as it is. To solve this issue I was thinking of buying a cheaper 997.1 manual as an additional car to then tune up but I spent a sack of money on my last one with all the usual issues and they are overpriced now based on their known issues. The Hartech rebuilt ones are pushing gen 2 prices.
Greenman986S
why not just retrofit the PSE....
unfortunately they dont do one for the turbo- there are only after market options
