Late turbo windscreen washer pump
- Thread starter blade7
robwright
MJL944
To do so you will need a thin forearm and you will be working blind/by feel! Popeye arms aren't going to fly for this job!
- Lift the headlights up via the knob under the rubber cover to create space for your arm's descent into the depths.
- At this point you may be able to catch sight of the top of the washer pump down in the depths with the aid of an inspection lamp.
- The washer pump is held securely in place in 2 ways - 1. the recess in the plastic reservoir which the pump sits in has a couple of notches which clip the main body of the pump firmly into position 2. the thin stem at the bottom of the pump sits tightly inside a rubber bung.
- To remove the pump you need to (by feel, as you can't see what you're doing when your hand goes down towards the pump) feel for the top of the washer pump and try to force a finger tip down between the pump and the reservoir body until the pump pops away from the reservoir. It'll pop away quite meatily and audibly.
- At this stage the pump will still be attached to the reservoir via the stem at the bottom of the pump still sitting in a rubber bung.
- Grab the top of the loosened pump and pull it up until the bottom stem pops out from the bung.
- Once the stem pops out, cue the sound of running water as washer fluid flows out from the bung (or remove as much fluid from the reservoir prior to pump removal!).
- The pump is now free for you to carefully pull it up to the top of the engine bay. Careful as it will still be attached to the washer fluid pipework and it may snag on things as you bring it up.
- You can now change the pump easily but good luck working with those horrible Oetiker clips/clamps that Porsche used to attach the washer pipework to the pump - I actually refitted a new washer pump without using a clip and the pipe has remained happily attached to the motor for over 2 years now (see my forum post here).
- To refit the pump into the reservoir you'll just need to make sure the pump's stem firmly pops into the bung (you feel and hear it) and that the pump's body then audibly snaps back into the recess on the reservoir.
I'd say it's well worth attempting this method to save yourself the horrors of access from below or needing to basically dismantle the engine bay to remove the reservoir itself! If your arms aren't up to the job, you could borrow someone else's maybe?
Good luck!
Mark
blade7
Well-known member
Paul
MJL944
Mine's an S2 also with headlamp washers.
Looking at the photos I took at the time it's the pump nearest the head lamp (basically directly under it - but a long way down) with 1 green and 1 brown wire coming from the top - those wires are pretty much all you can see with the naked eye from above. From memory it's much the trickier of the 2 pumps to access and remove - natch!
I may even have used a long flat blade screwdriver to lever the pump body away but obviously go easy as you'll be working blind and 30 year old brittle reservoir plastic won't take kindly to being prodded with a metal blade and the pump does require a fair shove to lever the body away from the tangs/notches on the reservoir that clip it in place.
Remember, once the pump body pops out, the thin shaft at the bottom of the pump will still be firmly gripped inside a rubber bung but with it being a rubber bung the pump will now pivot a fair amount.
P/N 92862817201 for a new washer pump - £25 or so from OPC.
See pic of washer pump here and note the thin shaft that sits in the bung which I'm referring to.
MJL944
blade7 said:.......maybe a tool could hook under the pump, or grip the top to pull it up.
I doubt either option very much - you'll feel the reasons why once you get your hand/finger-tips down there. Working blind and a lack of space being just 2 reasons.
Once you've popped the pump's body away from the reservoir as described, you're over the most difficult part (Oetiker clamp battle notwithstanding).
blade7
Well-known member
Its sometimes possible to free up a seized washer pump by reversing the polarity of the electrical feed to the pump & pulsing it by disconnecting & re-connecting the power, (obviously whilst disconnected from the vehicle wiring in order to prevent damage to ECU & other electrical components).
With care this can be done with the Tank / pump still in situ.
blade7
Well-known member
Thanks for the tip, took my spare battery down the tip recently thoughBenEngland said:If its the pump that has seized.
Craigybaby
Everything going relatively smoothly up until getting the pump back in...I can feel the washer attached to the tank with my long skinny finger, but can't for the life of me locate the pump in it...I bought a £10 pump, which looks the same overall dimensions but some of the grooves on the side are a little different, do you think this could be an issue?
Kind regards
Craigybaby
Managed to locate it properly....tested and all works fine...ten quid and an hour well spent... Thanks to the above guidance, helped a lot and gave me confidence to have a bash...
chrisg
However, when it comes to washer tanks and accessing pumps....
I'll see you and raise you for BMW X5 E70 = 2006 -2011 - I had the 'joy' of repairing a washer piper on one of these...
OMG..... the washer tank is the new trendy design where all you can see from the outside is the filler cap and swan neck....
As the Plastic front wings are integrated into a section of the front bumper you'd have to remove the whole lot ~ 3hrs works to get at the washer pumps.
Fortunately, I didn't have to do this but..... Still took me 2 hrs of mudflap, inner wheel arch, shield etc and unwrapping tape to access the split hose......
So..... 944 tank and pumps = Easy in comparison.....
BTW with my X5 - previous generation washer pump (3 of them for front, back and headights) can be changed in ~ 30secs.....
