MJL944
Gents,
With no washer fluid emerging from one of my windscreen washers, I've taken the T-piece off (see photo below) and, as expected, found it was clogged with gunk. The huge struggle to get all the pipe work off has wrecked the T-piece and valve so a new one will be ordered.
Incidentally, I did manage to change the washer motor without having to go at it from underneath as is advised (I have the deep S2 headlight washer tank with the screen washer motor sitting in the bowels of the engine bay!) but I do have thin arms which certainly helps!
Also, my top tip is don't not use your windscreen washers for 6 months (since April!) because when you do finally need to use them you'll probably find you have a seized washer motor and a T-piece with gunk growing in it!
Many thanks for any helpful answers,
Mark.
- However, before I also order 3 new metal clamps (over £3 each!) as seen below, how do I nip them up? Is there a special tool? I don't think pliers are going to crush them the right way. I might be able to reuse 1 or 2 of the 3 in the photo but they were nipped up so tight it's going to be a struggle.
- Or, would you recommend not using the metal clamps and maybe try cable-ties instead?
- Has anyone got away with not using either clamps or cable-ties? I quickly tried refitting the pipes without the clamps and they seem firmly fastened but as I've also fitted a new Porsche washer motor (which is seemingly MUCH more powerful than the 22 year old unit it replaced) I'm not sure whether the back pressure will force the joints apart without the help of clamps or cable-ties.
Mark.
