It's raining!
Neil1911
Well, it's a new experience for me and the 981 GTS I acquired on 17 July! This is my first experience of proper wind in the hair (I wish) motoring and there are no regrets at taking that step. My 2023 Macan S is still present so I feel as if all bases are covered.
Now, to the rain, an hour after it started I got into the car which had been getting drenched for an hour or so, all was well UNTIL I put the seat belt on, that was soaking wet, passenger belt dry as a bone.
Has anyone experienced this, is there a known cause and resolution?
Grateful thanks in anticipation.
Neil
I've had it on my 987S. Check all the Door and Roof seals and treat them with a Rubber Restorer. Also make sure Door Glass edges are clean and the window shuts properly. This does the trick for mine. The seals get mucky and need to be cleaned when the car does. Hope it resolves.
Roof drains 99.9%, one of the most common issues.
Get it fixed quick and make sure the carpets are dried out as any moisture will get into the electrics under the seats, it will get very expensive then.
Did you buy it from a trader?
Is it still under their warranty, if so they should take the sills off and remove the filters at the bottom of the drain tubes as these cause the blockage, similar to the Macan roof drains.
Rob
+1 for roof drains. They need to be sorted before damage occurs. Relatively easy to do yourself (even I did mine) - plenty of videos by searching "981 roof drains" or similar, including from this guy
Thanks all, just emailed to see about getting it sorted, now to get it out of the way of any more rain until it is....
It's going into Sheffield OPC next Wednesday. I was amazed at the short timescale and just hope that the warranty coverage also works out as good news...
Well, after being impressed by getting it in within a week it then took until Monday for them to tell me it had a blocked roof drain! "That's why I brought it in!" Oh, it's 2 hours work, not covered by the warranty so £450. "No thank you, at that price I'll invest in trim tools and do it myself", however, I'm not, it's with an Indy although he had a lot on and was a man (half the team) down so not back yet. Update on Saturday was that it was stripped and carpet out to dry.... watch this space ☺
As a matter of interest, did you buy it from Sheffield OPC or elsewhere?
No, I didn't, the local Indy that I'd been in touch with about post warranty servicing of my Macan knew I was in the market and put me onto it.
Agreed, however, Sheffield seems to be in black hole for such support. I ended up taking my macan to Cavendish Porscha in Nottingham for it's 40k service. The local Indy really seems more focused on 911 sales than anything else and doesn't have the manpower to cope with an already full plate, a shame, they are both good guys and a delight to visit!
I'm lucky, Zuffenhaus just south of Birmingham, less than 1 hour away.
They are busy doing all manner of the brand's products, but seem to be 'unfocused' to one type, an advantage I think.
Been going there for 7 years now. Not a glamorous place but straight as a die, and at my request, the same technician on my 987.2 Boxster each visit.
Indie's are rare on the ground around here too.
Soon be autumn!
Collected the car this afternoon, done and dusted, nil cost.
Blockage was "just a build up of dirt" pasenger side not affected. Now cleaned, valve not removed, but should be good for a long time to come 🤞
