Iffy starting
- Thread starter J4CKO
944 man
After thatd Id suspect that it was the FPR, as theyre getting as likely to fail now. Unfortunately the FPR for the S2 is unique and more expensive, so its not as easy to buy just to see...
Simon
944 man
This is why the cars always take a second or two to start up, as the second relay in the 'DME relay' powers up the fuel pump only when the engine is cranking sufficiently quickly.
Its possible that either relay in the 'DME relay' can start to play up or fail completely, so the symptoms can suggest either a ignition or fuel fault.
