Help ! cant get reverse !
- Thread starter J4CKO
"We are very sorry to hear that but sometimes if it is fitted in a way that it is crossing rear gear gear it does stop car from reversing, if you remove an dreinstall such that the end is on opposite side of gear then it will be fine, pls do let us know
- deutschepartsusa"
Make any sense ?
Realised my earlier selection issues were down to the original shifter, not so much the bit of play in it but the fact the metal shaft was stuck in the nylon bush when it should turn, worth checking if anyone is having a bit of a job getting gears, think it had just corroded internally and this stopped it turning.
Highwayman
It's certainly removed all of the sloppiness of the change that I had previously, and is also a much shorter throw now. It will take a little getting used to, but should be perfect for my intended track use.
Phil
Highwayman
Phil
