help advice needed
- Thread starter robwright
PSH
PSH
So rang the RAC, patrolman had a look under bonnet ....wd40 on coil, contact point, then the ignition ampliflier, car fires up everything fine , not taking ant risk drove it back up the drive (use my other car ).
Fire its up again around 5pm same day , everything fine ( thought just a bit of dampness in the contact point/coil/ampliflier thats why its did not start earlier ), anyway car was fine all week till this morning going to work (thought a nice day ,take the "S" for a spin, usually drive the M3 for work)turn on to the main road ( one laner )drove 300 hundreds yards ...car dies on me just before a small roundabout ! !
7:30am where I live is very heavy traffic ...(thought to myself Sh*t )on a narrow road with just one lane and heavy traffic , I can tell I was not the most popular person on that road
Call RAC again..... another patrolman inspect the car (explain to him previouse problem on last sunday)he then try to get it going with no joy, so he reccommend that he try to fit a new ignition amplifier and coil to try and get its going , after fitting the new amplifier(£83 !!!), but no new coil (none in stock), car still will not start, just the starter motor cranking the engine but no spark from the coil
he then went to see if all fuses are ok (they were fine)
No choice but to call recovery truck .....cut story short , got a phone call from the garage that the patrolman reccommended saying they are baffled and will need to call a Porsche specialist to inspect it next tuesday .
Now the thing is i had wash the engine bay last nite (carefully) and just rince the mucks off the bay with low pressure lance , start engine up to warm/clear the water in engine compartment , everything was fine with the car , drove the car to get some Pizza , no probs at all .
Did anyone on here encounter this problem before with thier car after a engine clean ?
also why would the garage say they cannot find the faults ...I not that cue up on car electrics but i would of thought it would be the ignition system that at faults (?)
any thought/ help/advice on this matter .
thanks in advance [
Mike.
PSH
robwright
PSH
Ahhh, been there Rob, on the M25 of all places, same symptons and same fix..ORIGINAL: robwright It is worth checking out the plug first mate. Just last year when I had just done the clutch on mine I went to pick up my friend Andy (Hairyarse) and his son. Upon giving his son a demo of the 944 power when I put my foot down I just got popping and farting and shite out of the back end which continued on and on all the way home.  Would run fine without putting your foot down then miss and pop and fart and smoke when you did. I was thinking F**K F**K this is big!! Turns out that one of the sensors had just come loose but not totally adrift from its plug socket on the harness. Pushed it back together and job done []
pete you are of course entitled to your opinion but to bad mouth all patrolmen is wrong i for 1 worked as an rac patrol for 5 years after 13 in the garage and all they do is train train train you im not saying the guys are all the same but your opinion dont let them work on your car is stupid why pay the money my fix rate was over 80% over 5 years and always asked where the customer wanted to go if not a roadside fix as there are no incentives to go anywhere else and if any cars suffered any damage due to a patrol the company were always the ones who paid for the repair but it was rare as we were all para of the ball kicking also ask any mechanic you know to apply for a job and im pretty sure he will tell you it is a very hard motor trade position to get my rant over sorry but i hate when people generalise thingsORIGINAL: PSH Hi Mike Going by your symptoms I'd be checking the crank sensor but firstly the engine multiplug between rear of engine and firewall assuming its in the same position as a turbo. Disconnect the plug and check for water trapped in the plug half's and also to see if any sign of corrosion. Give it a good clean removing any corroded muck , check it's dry, refit and try again. For future breakdowns I'd never let the (insert company name) take your car to a regular garage, in fact I wouldn't let a breakdown company touch it. The trouble is they don't know the car and one of the first things they try is to turn the engine over which is a big no, no possibly resulting in more damage. I've had my car breakdown twice, ( head gasket) both times I insisted a relay is sent out and not a patrol vehicle so that the car could be returned home were it could be examined properly. They will try to argue but will give up when they realise you know what your talking about. No I'm not a fan of breakdown vans except to get my car home, never let them work on the car. Rant over.... I've known a 944 suffer serious damage due to these breakdown experts... Anyway check these parts and if no joy let us know. Pete
PSH
peanut
