Helmets - Open Face or Full Face?
- Thread starter timarnold
Steve Brookes
Moderator
ORIGINAL: h_____
Steve, not sure I agree. Failure of anything on the front suspension can cause loss of brakes, even if the fluid remains in the system (err stub axle failure, bearing failure possibly). Hitting oil or coolant will pitch you off the circuit in a similar manor, and if you leave at high speed, grass/gravel might not do much to slow you down. I was suprised how far a heavy car like the porsche will travel in gravel even at low speed. Its very unpredictable what will happen, which I think is Tim's original point.
I fully agree that there can be other causes of sudden brake failure and of course know that you have personal experience of that. I've also heard of brake discs shattering. We can't foresee either of these things happening. However, I was referring to the point that Tim was told that they *thought* the cause of this particular incident was loss of fluid (and therefore pressure). Therefore this lead me to question whether the driver really hadn't had any signs earlier in the day of the impending disaster i.e. a soft/long pedal? I've come across many people at trackdays that have said that they're letting the brakes cool down because the pedal has gone soft....before they go out again!
I know this is all a bit off-topic and that the purpose of Tim's post was to discuss safety equipment but it got me thinking about whether the incident in his example *could* have been prevented.
I also agree about Melv's and your advice about that harnesses should be fitted and used correctly, so much so, that I removed my own 'road harnesses' this weekend because I felt they could do more harm than good in a big accident. Now I've just got to decide if I should get proper 6 point harnesses fitted in a car that has no cage. [&:]
ORIGINAL: Steve Brookes
ORIGINAL: h_____
Steve, if I stopped every time I had a soft a pedal, I'd never be out there! Personally, I think that overheating the brakes so you can feel a soft pedal, isnt a signal to park up for the day. Clearly it depends how bad it is, but often the brakes will come back to you, even by driving a bit more gently on the brakes will work.
I really cant advise if fitting harnesses without a cage is a good idea. I have heard bad things about it. Again, I recommend talking to Jen at MSAR, she really takes this stuff seriously and is very well informed.
timarnold
However, the point of my post was to bring to light the potential dangers of wearing an open face helmet, not what may or may not cause a driver's face to come into contact with the steering wheel in the first place. The fact is there are numerous circumstances that could cause that contact to happen, and there are numerous other objects that could come into contact with a drivers face in an accident. While it is certainly likely to be a more effective prevention than an inertia reel seat belt, wearing a full harness is not a guarantee that you won't take a bite out of the steering wheel in a head on impact, even if it is fitted correctly.
Neil Haughey
Neil Haughey
DSCBoy
BUT! I have seen too many people chew steering wheels because of open face helmets that I am of the opinion that open face should be banned. I would NEVER get out on a track in an open face. It's too hot? Uncomfortable? Diddums! Go knitting for the afternoon instead.
Similarly I've lost a couple of guys I knew because they were too stupid to buy a HANS device, preferring an extra set of tyres for the race weekend instead. Guessing their kids wished they'd bought the HANS device now.
Yes it's harsh. Yes it's the real world. But I get really f*cked off by people discussing safety on the web and convincing each other to take short cuts. (Not saying that the discussion here is of that nature).
It's really simple:
If your car has proper belts, you should be wearing a full face with HANS.
If your car has inertia real you should still be wearing full face and you should be asking some serious questions about how hard you want to push or whether you should be on the circuit at all.
Anything else is a stupid and inexcusable short cut.
Neil Haughey
ORIGINAL: h_____
Neil - if you race, do both! In amougst a years racing budget, £800 on saftey kit isnt going to hurt. At least you dont need to change the chassis mounts for the belts as welll.
I am actually contemplating going further and fitting a seat such as the Cobra evo ones with the ears and keeping the sparco rev as a bolt in/out passenger seat.
ORIGINAL: DSCBoy
In the interests of disclosure I should point out I have family links to both Stand 21 and HANS... I've raced with people who have died and I've had team mates walk away from crashes because they had the right safety gear.
It's really simple:
I've now bought a Schroth carbon Pro HANS device. Schroth helmet clips are on the way. My lid (Bell Sport4) has pre-drilled holes for the clips apparently. There are dimples in the lid but no holes. Are there threaded inserts beneath the surface? Do I just push the clips up against the helmet and twist until they break through? Anyone done this before?
Neil Haughey
ORIGINAL: h_____
Sounds like a good idea - got any pics? Maybe I should look on the 944 forum!! [] Sounds like a fun car
Well it should be back at EMC after its final blow over on Saturday, if it is there I will be taking some pictures so I guess its a watch this space. However being that is a maritime blue S2 prepped by EMC it will look very much like Mark Koeberle's car shown here
http://www.porscheclubgbforum.com/tm.asp?m=508694 Be warned though its a very long thread.
Main differences from Marks car are 1) its an S2 and not a turbo 2) Mine has been built from the ground up based on an acid dipped full motorsport prepped shell.
DSCBoy
Rick
TBH any half-competent person could fit them. It is a threaded post, a couple of washers and a nut. Obviously DSCBoy's wife will not be able to put on the certification sticker for motorsport use and neither can I.
Neil Haughey
jason
ORIGINAL: tim court
I use a HANS bought from the states when the £/$ was in our favour and it arrived complete with posts, spanner and a DVD describing in minute detail how to fit the posts, how to mark out the hole positions etc. etc.
Who fitted yours for you then Tim?[8D][
ORIGINAL: Neil Haughey
ORIGINAL: h_____
Well if its anything like that car, it will be really nice done - must be a great project. Will satisfying to get it on track.
