Has your 944 ever "Bitten" you ?
- Thread starter J4CKO
http://www.youtube.com/watch?v=Zxg2whz9mL8
and how to do it properly..
http://www.youtube.com/watch?v=MXxO84tJl04
Neil Haughey
5lab the ring looked amazingly wet in your vid, always a concern with that much water that you could end up aquaplaning at speed, something which is a nightmare for track drivers.
944 man
What speed were you doing around Brunchen?
I think into brunchen I'm about mid-way through third, so 60ish? it really wan't a day for going fast. Our ring taxi lap to over 11 mins!
On the last lap there was tonnes of standing water in parts, and given I'd aquaplaned off a dual carrigeway in similar conditions (see page 4) I was taking it very easy in the fast bits - probably never really going above 70. That lap was over a minute down on my 'moist' lap to give an idea of how slow I was. that said, the ring taxi didn't have a problem hitting 140 in the damp, so maybe i'm just a woose
Fortuitousness it was dry when I took my 998cc Mini on but here's the vid for laughs:
http://www.youtube.com/watch?v=ZGkiiAZcZhw
edh
ORIGINAL: 5lab
I only did 4 laps last weekend as it was pissing down the whole time. was fun but majorly slippery. theres a vid here http://www.youtube.com/watch?v=9QTdPms-86c of the v8 vantage ring taxi struggling to stay ahead of someone in a megane, should give you an idea how tricky it was with rwd
On the last lap there was tonnes of standing water in parts, and given I'd aquaplaned off a dual carrigeway in similar conditions (see page 4) I was taking it very easy in the fast bits - probably never really going above 70. That lap was over a minute down on my 'moist' lap to give an idea of how slow I was. that said, the ring taxi didn't have a problem hitting 140 in the damp, so maybe i'm just a woose![]()
Well done at brunnchen
If you watch the Aston, he's driving the wet line & staying well out of most of the apexes - I suspect that your "moments" came where the dry line was very slippery. Dale Lomas did a vid a few months ago in his RX-8 showing the wet lines & the massive difference in grip on the dry line (and the way the car reacted as you crossed the dry line)
Driving the 'ring without a helmet - I wouldn't...
Nick, I hear you re not using parts again like Seat, harness...but I hadn't thought about the cage. My only question is that in my case I hit a tyre wall which absorbed a lot of the impact in addition to the outside panels crumpling in. I know cages can be pretty cheap in various parts of the world. I even contemplated buying one of those kit cages out of the UK at one time...but a custom cage down here is expensive. $5k+ In your opinion is there any way of testing the cage to determine the risks of re-using? What are you going to do Neil?
ORIGINAL: 944 man
Yes, although you both need one. I think that one person of two wearing a helmet is even more dangerous in the event of an off.
The accepted wisdom is that the wet line around the Nordschleife, is anywhere that isnt the racing line!
its hard to stay off the racing line though, it becomes instinct. I think the real difference is on a few corners, if you watch the ring taxi and megane they took a very wide line round a couple of corners, but normal round most of the others...
regarding helmets, I think it depends how hard you're going to drive. I drive the ring like a fast, one-way b-road, where you know nothing will jump out at you. Sure I reached the limits of grip a couple of times, but not much really. Whilst a swift time would make me feel good, I'm not out to shave another 10 seconds off.
If I'm on a track, I'm going to be pushing grip limits as much as possible, to push times down. Whilst the margins for error (ie length of grass) are higher, the chances of getting there are also higher, so a helmet becomes more essential. I wouldn't fit in my 944 with one on anyway, so I guess the point is moot
Neil Haughey
nicksonmsport
ORIGINAL: 333pg333
Arrggghhh....sorry to see that Neil!! Ouch! Looks like the front end is a bit messed up too but perhaps all those panels are reusable? What tyres were you running? Seems pretty damp, enough to use wets?
tbh its very hard to test the cage, its a case of piece of mind, if i had a hard impact in any caged car, i myself would replace it to be sure it was good as new. the cage is like any other part for the body, in that it is designed to absorb and distribute the loads from an impact. tubes can flex and return to the original postion and you wouldnt know! the only way you may see any sign of the tube moving is to inspect the paint and check for any ripples or cracks etc. yes a tyre wall and surrounding panels will absorb the majority of the impact, but that was a large impact, and it was side on with the car stopping abruptly. also check any of the mount points on the sills in case the sills have moved in at all and brought the cage in with it.
at the end of the day a cage is a critical safety item in a race car, and to reuse a cage that has been in a heavy impact is a large risk.
Neil Haughey
In hindsight I think I was very unlucky to hit the end of one section of armco to be spun round the break into the next section, I reckon if I hit later or earlier the very shallow angle would have left much less damage. Further than that its pretty gutting that so many ppl went off that weekend yet managed to not hit anything, I have one off and end up with a smashed in car.
nicksonmsport
Somehow 18 months off the road and crashing (potentially?) first time back requiring a full rebuild in another tub seems not to be very cost effective. [
Neil, that seems ridiculous to be forced into using MPSCs as the tyre of choice...ESPECIALLY in the U.K. Mind boggling stuff!
Neil Haughey
The main reason why we have Michelin is because of the relationship between them and Porsche, the championship here whilst not on TV is an MSA sanctioned championship so it has a profile way up above us with the wider company etc. Personally I think Michelin make the best road car tyres available and I don't have a problem with them being expensive, I do have a problem with the characteristics of the cups though being the exact opposite of what a club racer wants and a prehistoric design.
