Fuel hose recall
Attcars
The owners of certain model variants and production years have received the same letters from Porsche GB as attached; first in November and now a reminder recently.
On the second page, it says "Please contact your preferred Porsche Centre to arrange an appointment to you to have this essential recall carried out on your vehicle. The necessary work will be carried out free of charge."
Apart from the fact that on most/many/all (?) cars the OEM fuel hoses will have been replaced long ago (as on my car), the problem appears to be finding a Porsche Centre actually willing to take this on.
My nearest 'Centre' - Portsmouth - was not interested and pointed me to a 'Classic Partner', specifically Porsche Centre Bournemouth. Having never heard of these 'Classic Partners', I googled the term and found there are five across the country. Swindon would be marginally easier for me to reach (still a two-hour drive each way!), so I called them. They said they'd call me back; they haven't. On Facebook, others have reported similar problems with disinterested 'OPCs'.
I am therefore done with running after Porsche Centres and emailed Porsche GB yesterday. Let's see if I get a reply; I'm not holding my breath.
Ultimately, it appears to me the problem is proving to the DVSA that the fuel hoses on your car are not the original ones and safe. But how to do that?Document_2026-08-24_122057.jpg
No outstanding recall listed when I checked the MOT history on my 91 turbo. I thought this originally related to the short fuel hose on the fuel rail.
I booked my 86 turbo in with the Porsche Centre in Swindon, the first one I tried after I received the letter. They seemed pretty happy to take it on and did the work whilst I waited including a thorough vehicle inspection.
Yeah, that model year is clearly unaffected. A close friend also has a 91 turbo and has not had the letters either.
Interesting! So what work did they actually do? Did they replace the hoses? Were they original, or had they been replaced previously and were they deemed to be fine?
(My car is also an 86 Turbo).
I have just moved house, so my letter might have been sent to the previous address. But I found this link to Porsche AG where you can look up recalls specific to your car's VIN:
In my case, 1986 944 turbo, no recall was listed. To put my mind to rest could someone who has had the letter put their VIN into this sites search bar and tell us if Porsche AG are listing the recall?
Yes, mine shows up - recall code AK03, which is - astoundingly - dated Mar 30, 1990.
It says:
"Description
There is a possibility that a fuel hose fitted, may harden and crack at the joint."
It says:
"Description
We both have 1986 turbos one with the recall and without!
I should have paid more attention, the only new part I believe is the connection between the fuel rail and FPR which is part flex and part rigid tube. The feed and return from the tank were not changed
I guess it must come down to month/day of production
My understanding is that all vehicles are at risk due to degradation and fuel leakage from the hose which can (and has) lead to many fires, hence the recall. My advice would be that any 944 with an original or ageing part needs to have a new part fitted whether under recall or not.
Thanks. Just checked myS2. Not required (Manufactured 9/90, 1st Reg 1/92).
Might get fuel pipes chcked anyway.
I reckon all of the 35+ year old fuel hoses under the bonnet need replacing. And I'm not convinced the yank cut and shut option I used is the best option from an engineering point of view. Though at least if they leaked, it would be in the wheel arch, rather than onto the exhaust manifold.
No recall for my 86 turbo...mind you those parts have been changed a number of times during my 27 years ownership...🙂
