flat battery
- Thread starter Alpine
appletonn
ORIGINAL: sc0tty
Many thanks chaps. Good explanation there Paul. I just have the charger temporarily connected at the moment. Paul, the ctek permanent wiring has a propriatary connector at the end of the + and ground wires that are on the battery, so at least it is not just bare wires !
Scotty, according to the CTEK uk website, you can buy a different cable to that one in the picture (same as the one on mine) which includes an inline fuse - might investigate that myself as Paul's comment made me sit up and think!
You could try putting a multimeter across the fuse terminals, after removing the fuse. That will tell if that circuit is drawing, and how much current. Repeat for each fuse.
Once you've identified the problem circuit you can check the fuse card to see what's on that particular circuit.
andy watson
Moderator
Copperman05
Edd
andy watson
Moderator
